change rear gears
Old 04-29-2014, 05:54 PM
drewsky
drewsky's Avatar
Guys, if you change the ratio to a higher gear and don't fix the speedo it put put A LOT of extra miles on your car that you didn't drive. Get it fixed. And I don't understand why ford wouldn't be able to hook up a tuner and do it for you..... 3:73 is a ratio offered by ford. If they don't (which would blow my mind) then grab a used tuner and it maybe borrow one.
drewsky is offline
Old 04-29-2014, 06:54 PM
tw1234
tw1234's Avatar
I believe you'll probably need a written tune for an automatic if gears are changed as the shift patterns are set for the gears it came with.
tw1234 is offline
Old 04-30-2014, 12:40 AM
Simon1
Simon1's Avatar
Originally Posted by scottmach
Nope.
They did mine in my 2001.
Simon1 is offline
Old 04-30-2014, 04:14 PM
scottmach
scottmach's Avatar
Because 3.73's aren't an option on the auto.
How is that even remotely the same thing here?
scottmach is offline
Old 05-01-2014, 01:47 AM
drewsky
drewsky's Avatar
Regardless if ford can't or not, getting a tune from either Breenspeed or AmericanMuscle will help a lot! Shift points will change and be vastly improved, you can add a lot if power even without a cai (but I'd recommend it while your getting a tune) and be able to adjust the speedo. Two birds with one stone and a lot if extra throttle response and power!
drewsky is offline
Old 05-01-2014, 04:26 PM
Simon1
Simon1's Avatar
Um...Maybe because it is the same exact technology by the same company? It's not rocket science. The dealership not only has the tools to do it, but they also hire outside tuners to vehicles. So yes, it is remotely the same thing.
Next time figure it out before you go spouting off half cocked.
Simon1 is offline
Old 05-01-2014, 04:40 PM
moosestang
moosestang's Avatar
Just get the tuner! a custom tune is as good as gears. Getting rid of the factory throttle lag alone is worth the cost. It's not like you have a 5.0 that like to go pop with an aftermarket tune, lol!
moosestang is offline
Old 05-01-2014, 06:57 PM
scottmach
scottmach's Avatar
I will say it once again so even your feeble mind will get it. 3.73's are not an option with the autos so therefor there is nothing a dealer can do. An aftermarket tune is the only option.
And technology has changed since 2001.
Old 05-02-2014, 04:59 AM
ashleesmach1
ashleesmach1's Avatar
jeez I did not mean to start such an argument. So I will just ask my local dealer then
ashleesmach1 is offline
Old 05-04-2014, 08:09 PM
Simon1
Simon1's Avatar
Well 3.31 weren't an option either in 01' either, but some how Ford figured it out, amazing! You are right, technology has changed, it's easier and easier to change things in cars like this, because of computers.
Feeble? You don't even know what the hell you are talking about. Probably never sat down with a tuner, aftermarket or from Ford, and learned what can and cannot be done with the tunes from cars.
Simon1 is offline
Quick Reply: change rear gears
