curious about these "platinum" services
Old 06-08-2014, 01:13 AM
kevsgt
kevsgt's Avatar
Default curious about these "platinum" services
Got an email from the dealership for this "platinum" service package (see attached .gif) on my 2006 stang now that it hit 90k miles. My service adviser conceded that it was overkill and gave the car just a regular checkup (I take it every 5000 miles, for oil change and such). Just wondering if i should have any of these performed next time? some of them i'm not even sure what they are?
- reset oil life system?
- install BG MOA oil conditioner
- Lubricate chassis components (which ones?)
- apply silicone grease to weatherstripping
- install BG frigi fresh sanitizer
- Replace spark plugs (90k is about the right time for this?)
- check operation of automatic transmission shift lock control?
- inspect evaporative control system and purge valve (if equipped)??
kevsgt is offline
Old 06-08-2014, 04:00 PM
sbradle4
sbradle4's Avatar
That sounds really high.
sbradle4 is offline
Old 06-08-2014, 07:37 PM
Nuke
Nuke's Avatar
There's a fool to be had somewhere. The only thing you need to do is your normal maintenance and if you desire, fluid changes. Fuel filter, too, if it's been over 30k-40k miles.
Nuke is offline
Old 06-08-2014, 07:41 PM
steel pony
steel pony's Avatar
Does this include parts should they be needed AND the labor to install them?? I have a lot of concerning questions with what's offered and the price, especially if we're talking about the spark plugs potentially breaking. It's a HUGE rip off considering you can to do #3, #6 yourself if you have the correct tools and use of a lift, #1 doesn't apply to your model year and #2, #4, #5 are either not worth it, not necessary or DIY
#2, #7, #8 may require a mechanic to check properly
#6 can be tricky if you break a plug.
There's no reason why you can't get this done for close to $200
- reset oil life system? NOT WORTH IT (not worth it for ANY car...should be part of the oil change
- install BG MOA oil conditioner NOT WORTH IT
- Lubricate chassis components (which ones?) GOOD INVESTMENT
- apply silicone grease to weatherstripping NOT TOTALLY NECESSARY
- install BG frigi fresh sanitizer NOT WORTH IT
- Replace spark plugs (90k is about the right time for this?) GOOD INVESTMENT
- check operation of automatic transmission shift lock control? GOOD INVESTMENT
- inspect evaporative control system and purge valve (if equipped)?? GOOD INVESTMENT
steel pony is offline
Old 06-09-2014, 10:14 AM
kevsgt
kevsgt's Avatar
please explain what you mean by #1 is not applicable.
what chassis components are we talking about lubricating? The bushings in the control arms? Anything else?
What weatherstripping are we talking about? between the side door windows and the roof? Are there others? Would they take the whole piece out and lather it with grease, wipe it dry and then reinstall?
Probably too complicated to describe in a couple sentences, but what is the shift lock control.
kevsgt is offline
Old 06-09-2014, 11:31 AM
jz78817
jz78817's Avatar
they're very good.
At making the dealer money, that is. Do what your owner's manual says to, and when it says to do it. Nothing more. Your oil and coolant don't need "conditioner," most of the other stuff you can do yourself if needed for like $10 out of pocket. And some of it is absolute LOL. How are they going to "inspect evap canister and purge valve?" If your check engine light isn't on or you don't have evap fault DTCs, it's working fine. And "check starter switch operation?" Uh, does the car start? If so, it's working fine!
That thing is a prime example of a rip-off. Something like that would make me stop going to that dealer for anything at all.
jz78817 is offline
Old 06-09-2014, 11:35 AM
jz78817
jz78817's Avatar
Usually the only lubricate-able chassis components are the ball joints and outer tie rods, but even then not always. And if they do need it, it's usually done as part of a routine oil change. control arm bushings are pretty tightly clamped in their mounts and usually have no provisions for being lubricated after the fact. Simply spraying white litho grease at them (which is probably what they do, if anything at all) isn't going to do anything worthwhile.
LOL probably not. Most likely some kid will take 5 seconds to wipe them with an Armor-All soaked rag.
it's the thing that makes you step on the brake before you can shift out of Park. It doesn't need inspection. If you can shift out of park, it's working. And there's nothing they can see by "inspecting" it that would indicate it's about to fail. Though I'm sure they'll see a "problem" with it and recommend you have them replace it (at an additional charge, of course.)
jz78817 is offline
Old 06-10-2014, 05:57 AM
steel pony
steel pony's Avatar
With the 2011+ models, Ford included what we will call an "Oil Dummy Light". I believe it's something thats on all of their cars now. It's set for 100% and chimes when it's time to change the oil (i think it's set for 10,000 miles).
You reset it by cycling thru the reset options on the dash. By them putting it on the paper they are making it seem like it's "something special" that needs taken care of, when in reality...they should be resetting it as part of the oil change. As this was a feature of 2011+ models, you do not have this feature built into your car and/or instrument panel/info
Old 06-10-2014, 08:49 AM
kevsgt
kevsgt's Avatar
thanks! while i'm sure most of you are biased against the stealership, this is informative and helpful.
kevsgt is offline
Old 06-10-2014, 09:26 AM
dcarlinf1
dcarlinf1's Avatar
I've said it many times, but I will only go to the dealer for two things, period.
1. Warranty repair (free)
2. For OEM parts, if needed
I will never use the dealer for servicing my car. And, this "special" is a prime example of why. It's an obvious attempt to get you in the service department so they can try to sell you on stuff you don't really need or you could DIY way cheaper. If you aren't comfortable with DIY, just find a local mechanic that operates on his reputation, not on marketing gimmicks.
dcarlinf1 is offline
Quick Reply: curious about these "platinum" services
