How to check what the previous owner has done
Hey guys, new member here, my baby girl is a 2006 mustang GT. It is my first Mustang I got it used a couple months ago. Im trying to figure out what the owner before me has done as far as performance upgrades. I can tell he put a exhaust on her, but there is no markings on it to tell me what type it is, anyone know how I can tell what type it is? also I believe my rear is not factory, my rpms seem a little higher then what I would think would come from the factory. SO basically what should I check and look over to tell if anything else has been done? It also has the hurst short shift. Thanks for any help!
To find out rear end gearing count turns of the drive shaft vs. turns of rear wheels. Jack up rear, put in neutral, and spin one wheel by hand. Might need to block other wheel to stop it from moving.
3.5 turns of DS per 1 turn of the wheel = 3.55, 3.75 turns = 3.73, 4 = 4.10, etc.
Mark the DS and wheel with a line to make counting easier. Then decode door tag to see if they match. Stock manual in 06 should be 3.55 I believe.
The door tag will be marked by 2 letters which will tell you what the original gears were.
CG = 3.31
CD = 3.55
Best bet would be to follow the advice above and count the drive shaft turns. If there is a variance, you want to get that looked at and have the speedo corrected for the right gears. Otherwise, you will essentially be putting miles on the car that you didn't actually drive due to the discrepancy.
CG = 3.31
CD = 3.55
Pics of all the major component areas of the car and you'll get your answers here.... Front wheel well (Strut assembly) Front under carriage (sway bars, radiator supports etc), Driveshaft, Rear end assembly (bottom and side view for ease), motor picture, exhaust from headers to mid pipe to axlebacks, pull up the shift boot (if its Manual) and a pic of the shifter as well... Plus an overall pic of the car for exterior cosmetic... or just general principle
Welcome to the club Be warned... modding is a disease and it never stops! Ask my future wife
CG = 3.31
CD = 3.55
CG = 3.31
CD = 3.55
Back when I had my 84 Monte Carlo SS (3 speed auto) I would run approx 3420 rpm at 70mph and I had a 3.42 rear end.
So, if this holds true, and you set aside some variance for tire size, then if the previous owner put 4.10's in for example, it should show on the tach.
Unless I'm sniffing glue and am way off on my facts, but I'm pretty sure I'm right.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
mungodrums
Suspension
09-07-2015 07:22 PM
