Loss of brakes after mutha thumprs
Loss of brakes after ***** thumprs
My brake pedal feels very hard and I've lost most of my braking, the car will come to a stop but in double or triple the time it took before the cams were put on. What is the problem?
it will feel hard and not want to stop only sometimes when the car is actually driving, but from a idle to a stop, it does it EVERY time.
Fwiw if the brakes needed to be bled, the pedal would be very soft or drop to the floor.
I have the ***** thumprs as well. As other users have stated, it's because of the vacuum drop due to the cams.
I did not install a booster, I just be sure to keep my rpms high enough while braking by rev matching and downshifting to keep enough vacuum pressure.
a reservoir can only draw down to the same amount of vacuum that the brake booster already sees (the booster has a check valve on it so it's already a bit of a reservoir) so that won't help. look to the way diesel engines do it; diesels have no throttle so they have no manifold vacuum at all. running power brakes means you need either an add-on vacuum pump, or convert over to a hydraulic brake booster (hydroboost) which is charged by the power steering pump.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
