Right signal lights out and left head light out help
My inside right turn signal started blinking fast which usually indicates a bulb going out. I replaced the right outer two bulbs that blink and no go. I replaced the front right turn bulb and no go. Then I noticed the left head light out? I replaced and still no lights. The high beam comes on the left bulb thats out. These lights also do not work when depressing the brakes and when the hazards are on. I haven't tried a test light in the harness yet, but thought I'd check if anyone has any ideas or have had or seen this problem.
Would hate to take somewhere if it is a quick fix like a moudule. And I found no fuse for these lights in the owners manual.
Thanks
Thanks
check for water leaking onto the sjb in the passenger kick panel. then check for water leaks around that general area. pull up the carpet and check for water. water leaking onto sjb causes all kinds of havoc and headache. good luck
