Speaker noise/buzz
Old 11-22-2014, 10:49 AM
Wright1308
Wright1308's Avatar
Default Speaker noise/buzz
I have 2010 mustang gt recently developed a driver door speaker buzzing. It doesn't do it all the time but it will do it on satellite, am/fm, aux and will stop if I hit the power button. It started after having a viper remote installed and that company says its not related to the remote start. I've had it in to ford service and they'd don't know. I've replaced the speaker and had service install foam tubing to door trim panel based on a TSB I found on the mustang forums. I have no aftermarket stereo equipment. It only does it sporadically so service has not heard it but I've recorded the noise and played it for them.
Any ideas?
Wright1308 is offline
Old 11-22-2014, 11:50 AM
PNYXPRESS
PNYXPRESS's Avatar
It's either a loose wire or a blown speaker. What you are hearing is electronic feedback thru the speaker
PNYXPRESS is offline
Old 11-22-2014, 12:16 PM
Wright1308
Wright1308's Avatar
I've replaced the speaker thinking it was blown but the noise continues. Maybe loose wire but service technician said he when he took door panel off he looked for anything that looked loose. Don't know how to proceed at this point.
Old 11-22-2014, 06:15 PM
Chromeshadow
Chromeshadow's Avatar
can you record it and post it?
Chromeshadow is offline
Old 11-22-2014, 07:39 PM
ticopowell
ticopowell's Avatar
It could be a crimp in the wires in the door hinge, or the wires coming out of the back of the radio, so check those before spending more money on it.
ticopowell is offline
Old 11-22-2014, 09:03 PM
roegs
roegs's Avatar
Well, if it started after the viper remote was installed and it did not do it before, it sounds to me like they need to do some more checking or disconnect their remote and see if the noise goes away.
roegs is offline
Old 11-23-2014, 11:57 AM
Wright1308
Wright1308's Avatar
Default Recording of noise
http://www.youtube.com/watch?v=eRTXWlzho9c
Old 11-23-2014, 12:04 PM
jz78817
jz78817's Avatar
that sounds like "GSM chatter." GSM phones (like AT&T and T-Mobile) use a particular frequency to negotiate with towers, and it's extremely common for that noise to be picked up by stereo systems. It's almost impossible to shield against because it gets picked up by the speaker wires and demodulated by the radio amplifier's negative feedback circuit.
If it started doing this after having the remote start was installed, then it must be related. It'd be worth finding out how the remote and the module in the car communicate with each other. I don't think there's anything Ford can do for you.
This is assuming, of course, that the stereo is working normally other than this chattering noise.
jz78817 is offline
Old 11-23-2014, 12:26 PM
Wright1308
Wright1308's Avatar
Wow! that is my noise! thank you jz78817. I have At&t too. so now wondering what to do...
Old 11-23-2014, 02:42 PM
Chromeshadow
Does your viper have the "cell phone" remote? Can you post the model number?
Quick Reply: Speaker noise/buzz
