05-14 convertible owners
Old 04-06-2015, 08:43 AM
bret1197
bret1197's Avatar
Default 05-14 convertible owners
Just got an 07 gt vert and was wondering how some of you have stiffened the chassis. My doors and windows rattle when I go over bad surfaces and I want to fix this before I move on to other things.alsp does a strut tower brace really help with cowl shake. Thanks stangers...
bret1197 is offline
Old 04-06-2015, 09:57 AM
bstang14
bstang14's Avatar
My 14 is pretty solid with very minimal cowl shake. I just finished lowering and stiffening suspension so we'll ser how much effect that has. Front strut tower brace is standard on 14 gt vert.
bstang14 is offline
Old 04-06-2015, 12:52 PM
Rudolph Hucker
Rudolph Hucker's Avatar
the vert is like a different car to the coupe..i had to sell mine after driving a coupe.
only thing the vert has as underneath support is those 2 skinny bars at the back lol..bit of a joke tbh
Rudolph Hucker is offline
Old 04-06-2015, 08:28 PM
jz78817
jz78817's Avatar
there's nothing to fix. Mustang is a unit-body car; the body is the structure. And the roof (along with the pillars) is a big part of that structure. losing the roof means the car must be less rigid. you can try bolting on some **** but it'll never be as rigid as the coupe.
nope. a strut tower brace improves handling by preventing changes in the front suspension geometry under cornering loads.
jz78817 is offline
Old 04-06-2015, 09:02 PM
bret1197
bret1197's Avatar
Had a fox body vert and sub frame connectors made a huge difference and that vert was held together with a few metal plates and pop rivets. So I would think this vert would be much better in the rigidity department
bret1197 is offline
Old 04-06-2015, 10:20 PM
BlindGUYnAR
BlindGUYnAR's Avatar
^ this. HD sub-frame connectors is about the only thing you could do. Welded would be better than bolt on.
BlindGUYnAR is offline
Old 04-07-2015, 05:45 AM
jz78817
jz78817's Avatar
I didn't say it wasn't! I just said it's not as rigid as the coupe.
jz78817 is offline
Old 04-07-2015, 11:57 PM
cruisin5268d
cruisin5268d's Avatar
My convertible is quite solid for normal driving. Sure, there's a difference between it and my couple under harder conditions - but that's the way things go. Don't get a convertible if you want a race car.
cruisin5268d is offline
Old 04-13-2015, 09:08 PM
Edmund K
Edmund K's Avatar
I just put a strut tower brace on my 05 Gt convertible today, and that annoying rattling of the mirrors and doors was reduced significantly, almost completely! The brace came from American Muscle; I went with the chrome version, since the engine bay is primarily all black. http://www.americanmuscle.com/sr-str...0509-gtv6.html Hope this helps!
Edmund K is offline
Old 04-14-2015, 05:05 AM
bret1197
bret1197's Avatar
Thanks for the info...gonna probably get one...hopefully it will help
bret1197 is offline
Quick Reply: 05-14 convertible owners
