Rough idle even after cleaning sensor and throttle body
I have a 2007 Mustang GT with JLT CAI, 62mm TB, and BAMA tune. Other stuff too, but not relevant to the engine.
The idle is rough and even one time surged like it was stuck and I had to shut it off. Thankfully I was in neutral. When I restarted it, it just bounced like normal.
This problem was rather gradual, noticing the dip and bounce when the condenser kicked on, so I thought I had an alternator problem, but voltage looked stable.
It progressively got worse so I cleaned the MAF and TB with their proper cleaners, and then did a reset "pulled battery" and let it re-calibrate and then drove it around, but still no resolve. It was actually even after the reset that when I turned it on it surged. For the reset, I have tried both steady and easy driving, and then driving like a wild man. Neither had an affect on the idle.
This was all last fall, so I put it away for the winter, so now it is time to start thinking again.
Thanks all.
Thanks all.
I'd re-clean the TB and also double check the MAF electrical connections. Have you tried another tune? When was the last time you replaced the fuel filter and ran a tank or 2 of fuel system cleaner? Are all of the intake joints/connections tight (no air in-leakage)?
I had cleaned the Throttle Body twice, and MAF 4 or 5 times. The tune from BAMA has worked fine in it for 3 years prior. There are no leaks (tested with ether spray), and tightened again just to be safe.
I have not however, replaced the fuel filter. I have 42k miles, so that is a good idea. It runs fine when I get on it though, and seems like the idle circuit (sorry for carb speak).
Any other thoughts? Known issues?
You can try trouble shooting things. I recall having some issues with WOT air/fuel. Tuner had me start the car without the MAF plugged in. The car should still run at idle if the tune is correct. Sometimes people clean MAFs and put them in backwards. It would help to rule out if the MAF is faulty. But honestly, the MAFs either just comepletly stops working or works fine so it's probably not your MAF since it works at WOT.
I have also seen people forget to hook up vacuum lines or have a vacuum leak.
Have you tried taking off the BBK throttle body? They are generally worth more weight in scrap metal than putting them on your car. I have seen a lot of them cause drivability issues.
Seriously, without hurting your ego, the thing is a gigantic piece of trash. You shoud take it off of the car and throw it in the garbage or use in your shop to hold something down. They are notorious for causing drivability issues and offer little to no gains. It takes a very large throttle body to make a difference and you need to ad FI to it to make it worth it.
I guess the info I have is second hand. But I have seen so many guys put that thing on their cars and then have it run like crap. Just try it. See if anything changes. Put the old one back on.
I wish it was as easy as taking it to a Ford service center, but we all know how that goes.
I see a lot of people have a problem with the OEM TPS failing and causing the same symptoms I am experiencing. I think I will replace it with the Motorcraft part. http://www.summitracing.com/parts/mof-dy1116
Unfortunately I will not be able to post an update on this until spring.
