2006 gt times
Old 03-27-2015, 02:21 AM
BismoFunyuns
BismoFunyuns's Avatar
Default 2006 gt times
With 320whp and 325wtq & 410s (Automatic), I went 13.2 @106mph with a 2.2 60ft. Does that sound about right or seem kinda slow? Seems like I should be in 12s with that trap?
BismoFunyuns is offline
Old 03-27-2015, 05:08 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
There's definitely room for improvement with that 2.2 60ft and 13.2 ET.
Do you still have the stock torque converter?
Any suspension mods?
Dino Dino Bambino is offline
Old 03-27-2015, 06:43 AM
outceltj
outceltj's Avatar
your 60ft needs work and you will be in the 12s
outceltj is offline
Old 03-27-2015, 12:22 PM
BismoFunyuns
Stock suspension and converter.. How could I improve the 60ft with street tires and an automatic? I think the back are Michelin 255s and 245s on the front
Old 03-27-2015, 03:14 PM
jz
jz's Avatar
I ran 13.4 @ 106 with a 1.9 60' the mods in my sig. Granted, my car is a stick but I had my most success lauching around 3k rpm. My rear tires are 285, Nitto 555.
jz is offline
Old 03-28-2015, 02:07 AM
outceltj
outceltj's Avatar
what are you doing when you go by the water box. how do you prepp right before you stage.
outceltj is offline
Old 03-28-2015, 08:12 AM
Dino Dino Bambino
1. Higher rpm stall converter.
2. More traction (tires and, at the very least, LCAs).
Old 03-30-2015, 12:33 AM
BismoFunyuns
i dont go through the water box.. I do a burnout just enough until theres a little smoke then launch til it hooks and stage. I know you're not supposed to do anything with normal tires but I've tried both and it seems like burnouts help just a little
Old 03-30-2015, 01:12 AM
outceltj
outceltj's Avatar
Yes a small turn of the tires will help a bit b/c your cleaning them but dont do anything excessive. The compound isnt the same as slicks. You can also try messing with your air pressure a bit as well. From what i can tell 1.9 to 2.0 seems to be about the best guys can get on street tires. You could get a set of rear slicks and then you would be better off. LCAS like previously stated.
outceltj is offline
Old 03-30-2015, 01:21 AM
Dino Dino Bambino
Yup. My 60ft was 1.89 and I'm on street radials.
Quick Reply: 2006 gt times
