Clutch doesn't fully disengage at high RPM
Old 04-11-2015, 12:12 AM
Mike_
Mike_'s Avatar
Default Clutch doesn't fully disengage at high RPM
The car is an 05 GT with 90,000 miles. Basically when I'm driving hard and shifting at over 5000rpm it is very hard to shift into the next gear, I have to forcibly put it in gear making quick shifts nearly impossible. Also after coming to a stop after driving hard it is extremely hard to put the car in any gear including reverse. On top of that when I redline the car with it in gear with the clutch fully depressed it will move forward (or backward if I'm in reverse) a foot or so.
Right now I'm thinking my clutch needs to be bled. Any ideas on what the problem might be?
Mike_ is offline
Old 04-11-2015, 12:28 AM
jwog666
jwog666's Avatar
sounds like a pilot bearing issue, pull the trans and inspect, if the pilot seizes up then it will drag the input shaft and cause your concern
jwog666 is offline
Old 04-11-2015, 12:38 AM
Mike_
Mike_'s Avatar
The thing is there isn't any noise from my trans at all. Pilot bearings usually make a sound when they are going.
Mike_ is offline
Old 04-11-2015, 07:21 AM
jwog666
jwog666's Avatar
not always, mine made no noise just got tight and made it hard to shift
jwog666 is offline
Old 04-12-2015, 10:42 AM
Slowbra302
Slowbra302's Avatar
I just replaced my clutch again (sigh). From a dead stop, I had to fight to get it in any gear. Once I was rolling I would just use the natural shift points. Anyways I had no noise or anything.
Apparently, my throw out bearing exploded with 27k miles on it. Not true if the 05's are cable clutch or not.
Slowbra302 is offline
Old 04-12-2015, 01:08 PM
jwog666
jwog666's Avatar
05 and up is hydraulic but would act the same if the throwout or pilot were bad,
jwog666 is offline
Old 04-13-2015, 05:12 PM
sactown
sactown's Avatar
I would think it is the throw out bearing, if you replace it just get another stock one from Ford, there is no reason to use an aftermarket TOB.
sactown is offline
MasterLanMan
09-13-2015 08:21 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
uedlose
09-10-2015 03:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Clutch doesn't fully disengage at high RPM
