Best way to make 2010 fogs look like 2013 fogs.
Old 04-12-2015, 04:58 PM
Greg251
Greg251's Avatar
Default Best way to make 2010 fogs look like 2013 fogs.
What is the best way to make 2010 fogs look like 2013/2014 fog lights. With a led kit or HID kit? and does anybody have any experience with certain kits they would reccomend
Greg251 is offline
Old 04-12-2015, 06:52 PM
cruisin5268d
cruisin5268d's Avatar
Welcome to the forum.
Which fogs are you looking for on the 2013/2014 models? That would be your best starting point. My honest advice to you would be to stick with what your 2010 has already. When you start using cheapo aftermarket HIDS and LEDS things start looking pretty ricer and cheap.
There are some forum members here that have done complete front end swaps to make it look good. Better have a few grand to throw away if you go this route.
cruisin5268d is offline
Old 04-13-2015, 06:07 AM
jz78817
jz78817's Avatar
no. your lights aren't a fashion accessory. if you put HIDs in them you're a terrible person.
jz78817 is offline
Old 04-13-2015, 06:35 PM
Greg251
Greg251's Avatar
I will take leaving them stock into account for now, but I bought the car and the person before me did a 2013 headlight swap on it correctly and I just want my fogs to match the OEM headlights. It would be the fogs mounted on the front grill
Greg251 is offline
Old 04-13-2015, 10:21 PM
cruisin5268d
+1,000,000,000,000,000,000
Confucius says, "Man who buys el-cheapo aftermarket 'HID' lights gets el-cheapo aftermarket 'HID' lights.
Old 04-14-2015, 06:02 AM
jz78817
jz78817's Avatar
Also say, "Man who walk through doorway sideways going to Bangkok."
jz78817 is offline
Old 04-14-2015, 01:55 PM
Greg251
Greg251's Avatar
thanks for totally answering my original question
Greg251 is offline
Old 04-14-2015, 03:07 PM
jz78817
jz78817's Avatar
putting HIDs in your fog lights is a bad thing to do and we're not going to tell you how to do it. I'm pretty sure you can't use the LED modules for the '13-'14 fogs; if they're not built into the housing then they're surely a non-standard part. and the cheap LED modules you can get to put in the place of halogens usually suck because the light source is all wrong for the reflector.
jz78817 is offline
Old 04-14-2015, 07:10 PM
CARBIllegal
CARBIllegal's Avatar
HID's will blind people, low wattage LEDs like raxioms will work and serve their purpose (for others to see you not for you to see others)
CARBIllegal is offline
Old 04-15-2015, 11:35 AM
ghunt
ghunt's Avatar
HID's in halogen housings are a no-no. They look terrible and produce a ton of glare.
ghunt is offline
Quick Reply: Best way to make 2010 fogs look like 2013 fogs.
