Rear Window blowing fuse
Hi everyone, have a problem on my 07 GT Convertible I'd like to run by you.
As soon as I press the rear window button a 5 amp fuse blows in the interior fuse box.
The front windows work no problem, but the second I press that rear switch the fuse pops.
I guess the first thing I was going to check was to disconnect the rear window motors and try the switch again to see if the fuse blows. If it doesn't than I know it's not the switch and its one of the motors, right? Than just through process of elimination I can plug the motors back in one at a time to figure out which is bad.
Does that sound like a good way to proceed?
And if so, can anyone tell me the best way to get to the rear window motors to disconnect them?
Thanks much!
Justin
Thanks much!
Justin
I think you got some good info on your other thread.
Keep at it - somewhere something is happening to cause this issue. By process of elimination you'll find it eventually. Maybe it's a simple short in an easily accessible place.
