2007 factory options - rear end
Old 07-03-2015, 01:59 PM
goldenglory18
goldenglory18's Avatar
Default 2007 factory options - rear end
All,
Does anyone remember what the option code was for the 3.73 upgrade in the 07-08 GT's? I halfway remember it being paired with the spoiler delete, but the more I think about it, the more I think they were independent of each other.
I'm looking at a used GT here in LA that has the spoiler delete. I want to figure out if it has the taller rear end as well.
Thanks all...
Kenny in LA
goldenglory18 is offline
Old 07-03-2015, 04:27 PM
bl817
bl817's Avatar
the tag on the rear diff cover should tell you what ratio it has. if not, the door sticker on the drivers side should.
bl817 is offline
Old 07-04-2015, 12:12 AM
goldenglory18
Ahh, totally forgot about the door tag. Thanks a bunch!
Old 07-08-2015, 07:07 PM
jz
jz's Avatar
I can't see the spoiler delete being connected to the rear end option. I would use the pumpkin sticker since it will simply say the gear ratio. I can see mine without jacking up the car.
jz is offline
Old 07-11-2015, 06:57 PM
SpartaPerformance
SpartaPerformance's Avatar
3.73 was a stand alone option, best way to tell is tag on rear diff or the axle code on the door plaque
SpartaPerformance is offline
GimpyHSHS
08-29-2015 06:30 PM
movielover40
08-27-2015 10:13 PM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
Quick Reply: 2007 factory options - rear end
