Throttle response questions......
Old 06-10-2016, 07:59 PM
doubleoh
doubleoh's Avatar
Default Throttle response questions......
I've used my 2012 Fusion AND 2014 Flex at the track and throttle response is almost non existent. Hopefully, the Coyote 5.0 (which is what I'm looking to buy) has a better record. Can these drive by wire THROTTLE controls be tweaked to EQUAL a Holley double pumper carb. Is the computer re-programmable to speed up engine response and work as good as my bracket racer with Holley carb?
doubleoh is offline
Old 06-11-2016, 09:15 AM
P51C
P51C's Avatar
Short answer is yes.
Longer answer is throttle today has many things that it intersects with, ABS, SC/TC, rev limiter, engine management, transmission strategy, etc. So, the performance can be variable depending on the circumstances.
However, any decent tune turns the throttle response way up and removes the factory delay programmed in for idiots out there.
P51C is offline
Old 06-11-2016, 10:50 AM
doubleoh
doubleoh's Avatar
Very good. Thank you.
doubleoh is offline
Old 06-12-2016, 03:39 AM
09GT/CS
09GT/CS's Avatar
Absolutely as said above. Also when you get your tune make sure you list all performance parts. The can really fine tune it when they know exactly what you have. The tune is night and day on the drive by wire cars.
09GT/CS is offline
Old 07-04-2016, 08:08 PM
808muscle
808muscle's Avatar
Tune is everything. I have a race tune that LEAPS off the line! LOL
808muscle is offline
Old 07-05-2016, 03:56 PM
ghunt
ghunt's Avatar
Factory drive by wire throttle response on these cars is junk IMO. Big dead spot at first throttle tip-in. A tune helps big time.
ghunt is offline
Tommy_gun
04-15-2016 08:01 AM
oct1307010
04-11-2016 07:31 AM
Mach2
04-01-2016 03:37 AM
tgprof
03-26-2016 07:53 PM
Galicia Fabian
03-24-2016 01:02 PM
Quick Reply: Throttle response questions......
