I still can't remove my center console
Old 07-13-2016, 12:10 PM
lmarlo
lmarlo's Avatar
Default I still can't remove my center console
Greetings - I've read the instructions from multiple sources, and the darned thing still won't come loose on my '07 GT. (It has some scratches and I want to repaint the top half). I removed the 2 nuts in the little compartment where the piece of carpet is. I removed the 2 screws on top in the rear. After removing the shift **** and boot, I removed the 2 small hex bolts that are inside "up front and on each side". I lift up from the rear as instructed, and it is still somehow attached up front. I looked and it appears there are clips holding it where the hex bolts were. Please tell me what I'm doing wrong.
lmarlo is offline
Old 07-14-2016, 02:16 AM
danzcool
danzcool's Avatar
I assume you've seen this sheet?
http://iihs.net/fsm/?dir=461&viewfil...le%20Floor.pdf
danzcool is offline
Old 07-15-2016, 12:16 PM
lmarlo
lmarlo's Avatar
Thanks - Yes - I saw the schematic. I got it off finally. I watched a video and the guy just gently lifted it off. I ended up standing in the back using a prying tool and it came loose. Evidently, mine was a really tight fit.
lmarlo is offline
Old 07-15-2016, 06:00 PM
danzcool
danzcool's Avatar
Seems like I remember about the same when I pulled mine up to do sound matting... but I think I initially didn't see the nuts near the back and then went to find the schematics to see what I was missing.
danzcool is offline
01S2Roush
12
05-15-2016 03:34 PM
TEXASGT/CS
04-25-2016 09:54 AM
HRDWRK
5.0L V8 Technical Discussions
04-23-2016 08:33 AM
Lee1911
Convertible Tech
04-18-2016 11:56 AM
carid
04-18-2016 08:16 AM
Quick Reply: I still can't remove my center console
