Lack of brake booster vacuum.....2014 GT
Has anyone had a problem with not enough vacuum for brakes? Or had vacuum depleted quickly with several rapid pumps of the pedal...leading to a hard pedal and lack of braking?
My mustang seems to be acting up with this also. 98 V6. Brakes have initial pressure but after about 10 seconds or so, the start to sink as if the booster had a leak. I've replaced rotors, calipers, hoses, master cylinder (original problem with leaking seals causing the brakes to clamp down), new brake booster (leaking master cylinder caused fluid to travel into the booster and eat up components), and a new vacuum hose for the booster. I'm not loosing brake fluid and i have full brake pads. ABS acting up??? Any help for our posts would be tremendously appreciated.
Are you sure it's vacuum and not bad fluid or air in the lines? I would replace the brake fluid with Motul RBF600 and make sure it's bled properly. Also, as said before check hose from manifold to booster.
I'd lean more towards ATE Typ 200 (this one replaces the legendary ATE Blue and is good for up to 3 years) or ATE SL.6 fluid for LV.
Not sure if its the case with newer mustangs, turns out my air intake manifold seal above the plenum is leaking. Loss of vacuum is affecting the booster (let alone not supplying the correct amount of air to the cylinders). When you've looked at everything that has been fixed, look at whats left. So back to the posts original question, if the mechanics of the brakes are working properly, try looking at what works in conjunction with your brake system. Ex. vacuum and with newer cars, electronics.
