2014 GT axle replacement
Old 02-16-2017, 01:47 PM
Daleford
Daleford's Avatar
Default 2014 GT axle replacement
I am repairing a damaged 2014 GT that was hit on the right side. The axel broke off at the flange. The salvage yards are saying it is the same right rear axel from 2005 to 2014, V-8 or V-6, no difference. Is this true?
I have found parts cars at "you pick and pull" yards. What wrenches do I need carry to get an axel removed?
Lastly, is there anything to look for? I know some older Ford vehicle had the axel bearings running directly on the axel shaft and this would wear out this area.
THANKS in advance for any info................
Daleford is offline
Old 02-16-2017, 07:22 PM
Moderator
JimC's Avatar
No it isn't true. The 2005-10 V6 used a 28 spline 7.5" rear end with an open differential.
In 2011 all Mustangs have the same rear end so it doesn't matter what you pull it from if it is a 2011+ car. If it is coming from a 2005-10 then you have to pull from a GT.
JimC is offline
Old 02-16-2017, 07:29 PM
Daleford
Daleford's Avatar
Good info - THANKS
Also talked to a Ford mechanic who said the bearing runs directly on the axel shaft [no race] Said there hasn't been much problem with them.
Daleford is offline
Old 02-18-2017, 09:50 PM
flash_xx
flash_xx's Avatar
If the price is right I'd just take the whole rear end, you don't know what else might have been damaged.
flash_xx is offline
Old 02-19-2017, 08:20 AM
P51C
P51C's Avatar
That's a 31 spline axle in there, common to all 11+ Mustang GTs. Chances are good if it broke the axle flange, it's banged the differential pretty hard, too. You might want to have a close look at that, before buying just an axle.
P51C is offline
Old 02-19-2017, 12:13 PM
Moderator
JimC's Avatar
Originally Posted by P51C
That's a 31 spline axle in there, common to all 11+ Mustangs.
Fixed that for you - every Mustang starting in 2011 to 2014 has the 31 spline 8.8 rear end, not just the GT. For 2005 to 2010 only the GT had the 31 spline 8.8 rear end.
And excellent point. If you damaged the axle on your car, chances are something else has happened. So just get the entire rear end and swap it. Probably cost you about the same anyway.
JimC is offline
Old 03-12-2017, 09:09 PM
Daleford
Daleford's Avatar
THANKS for info.
Next question - Are the left axel and the right axel interchangeable?
Daleford is offline
Old 03-13-2017, 05:32 AM
Moderator
JimC's Avatar
Originally Posted by Daleford
THANKS for info.
Next question - Are the left axle and the right axle interchangeable?
No. They are different lengths.
JimC is offline
Old 03-13-2017, 05:54 AM
Daleford
Daleford's Avatar
Wow, so the guy selling me the left axel to go into the right side of my car was wrong!
Does anyone know the 2 different lengths of the shafts so I can get it right.
Daleford is offline
Old 03-13-2017, 11:12 AM
Daleford
Daleford's Avatar
Don't want to argue with a moderator but here is a different answer for another Mustanger......
What do I do??
They are both the SAME length, they are 31 spline and they are made out of either SAE 1055 or 1541 carbon steel. Hope this is the info you were looking for.
Daleford is offline
Quick Reply: 2014 GT axle replacement
