Long tube header HP comparison
Old 12-31-2005, 02:34 AM
  #21
tradetheoex
tradetheoex's Avatar
Default RE: Long tube header HP comparison
I decided on the stainless works long tube headers and cats with connection pipes. The pipes after the headers don't connect to each other so I now have true dual exhaust. This is the way the kit comes. Not my ideal set up but the dyno info I posted from Stainless works in the previous post looked promising so I went with it. To my suprise, I LOST 12 FT-LBS of torque with the header swap! We dyno'ed it a few times to try to get the numbers up with fuel and timing but didn't have much luck. I ultimately left the tune the way it came from Brenspeed when I bought the C & L cold air kit and SCT tuner. I did pick up 11 Max Horsepower on the top end but the car makes alot less power under 4500 RPM. The numbers cross over @ 4500 RPM and then the HP picks up around 8-10 HP for the rest of the RPM range. I think part of the problem is that I went with the 1 & 3/4" primary tube headers per the recomendation of Stainless Works and the dyno numbers from them. If you compare my bone stock numbers before a tune, with the long tubes with a tune, I do see how they can gain 30 HP. But if you isolate the header install by itself you'll lose power under 4500 RPM. I may buy the 1 & 5/8 Primary tube headers and sell the 1 & 3/4 nes on Ebay. Anyone interested?
Has anyone installed the 1 & 5/8 Headers and then dyno'ed the results. I'd love to see the results.
tradetheoex is offline
Old 12-31-2005, 11:02 AM
  #22
RPM
RPM's Avatar
I would bet you will pick up a lot going to smaller primaries. The 1-3/4" primary is better suited for an application with a LOT more HP than what these 24v motors produce in stock form. A 1-1/2" primary test would be very interesting. May even work better in terms of average HP which is really the most importantfactor in a street application.
I was running 1-3/4" primaries on a 475HP Pontiac and that engine was just marginal with that header size. 1-5/8" would have worked as good.
RPM is offline
Old 01-04-2006, 01:33 PM
  #23
BIGGRED35
BIGGRED35's Avatar
ORIGINAL: tradetheoex
Kinda sad. Most people on the mustang forums are dyno tuning up top but losing on the bottom of the RPM scale. Are we really that interested in making a dyno queen out of a really bitchen street car?
"The average american spend 83.7% of their weekly drive below 3K RPM". (Qutoed from C&D) Why tune for anything other than
>4500 RPM?
BIGGRED35 is offline
Old 01-04-2006, 08:49 PM
  #24
Thump_rrr
Thump_rrr's Avatar
ORIGINAL: BIGGRED35
>4500 RPM?
The average american doesn't drive a Mustang GT and the average Mustang GT driver doesn't search the Mustang forums. We're more like the less than 1%.
Thump_rrr is offline
Old 01-04-2006, 09:44 PM
  #25
BuffPony
BuffPony's Avatar
I have stainless works 1 5/8" primaries w/ xpipe and their 3" exhaust.....Nice gains..
my review:
https://mustangforums.com/m_902595/tm.htm
BuffPony is offline
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: Long tube header HP comparison
