Lethal Performance offering Even Flow Cooling Mods!
Lethal Performance has a new product on the shelf, and it goes by the name Even Flow Cooling. The Even Flow Cooling Kit for 03/04 Cobra consists of a percision machined stainless steel fitting, custom made Aluminum Coolant T along with the Heater Hose and Adapters to connect the two. The Stainless Steel fitting is installed in the rear Coolant Jacket on the Drivers Side Head and the Aluminum "T" is installed at the upper Radiator Hose. This kit will improve coolant circulation through the Drivers Side Head, helping to eliminate hot spots and potential detonation at Cylinder #7 and #8.
The Stock cooling system on the 2003/2004 Cobra, along with other 4.6 DOHC Applications, has no provisions for the hot coolant to escape from the rear of the Drivers Side Head. This creating potential hot spots/steam pockets in and around the rear 2 Cylinders. By creating a direct path to the Radiator, coolant flow in this area in increased greatly.
Once this modification is installed, both cylinder Heads will be flowing coolant through a restriction averaging .350, thus maintaining EVEN coolant flow through both heads.
This kit can be installed from the top of the car (with the Blower Removed) and requires no removal of the transmission.
We will have these kits in stock and ready to ship out within a week, give us a call now and get your spot on the list!!
If you have any questions, please feel free to ask or PM Derek or I.
Thanks again,
Matt @ Lethal Performance
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Matthew Gerlach
LETHAL PERFORMANCE, INC.
http://www.lethalperformance.com
877-2LETHAL
561-620-0328
Matt@lethalperformance.com
You name it, WE got it!
