* -Optimized for 2005+ Ford Vehicles
* -Enhanced Horsepower
* -Enhanced Mileage -Enhanced Driveability
* -Positive Spark Plug Connection Point
* -High RPM Capability -Plug and Play Fit and Finish
* -Professional Level Technology
* -Super High Output Spark
COIL ON PLUG TECHNOLOGY
The creation of a high quality ignition system has been a challenging process for OEMS that has taken many years in research and development. Recently, technology has introduced to the automotive market the next generation of high performance ignition coils which offer the latest in ignition technology for improved spark output and engine reliability. With the latest cutting edge technology our engineering department has further refined ignition coil design to allow for improved power output with reduced noise emissions. The Coil On Plug ignition is the latest development in precisely controlling spark intensity and timing for optimum power,
fuel economy, and low emissions. Most 'coil on plug' (one coil for each spark plug) systems are actually 'coil near plug' because a short mechanical connector, or spark plug wire connects the coil to the plug. True coil on plug systems, with the coil mounted directly to the plug, are now being introduced on both domestic and foreign engines. One such example is the XCOP ignition coil which was developed for Ford engines.
A strong spark requires high voltage. In order to maintain the high voltage we must ensure energy output is not
compromised. One such method to accomplish this is through advanced circuit compression models.
CIRCUIT COMPRESSION
High-voltage circuits always risk degradation at any connection point between two parts. High voltage also will escape from its intended circuit whenever it finds an easier path to ground due to component failure or insulation breakdown. With coil on plug, there is no high-tension lead between the spark plug and the ignition coil. The system 'compresses' the secondary ignition to the minimum number of components and reduces the distance high-voltage circuit must travel.
Because of circuit compression overall system impedance and power loss is reduced, thus increasing the available power produced by the ignition core across the spark gap.
ADVANTAGE XCOP
Taking an existing coil and tweaking the internals for reproduction offers
COPY OEM COIL NEAR PLUG (CNP) DESIGN
* Cost savings, since there is zero development time in re-designing the packaging.
* Zero improvements on packaging, weight.
* Same voltage and power loss through the OEM connections and interconnect.
* Position, design and principals for the new ignition coils remains the same as OEM CNP units.
* Internals can be revised.
Creating a new ignition coil from scratch offered
CREATING A NEW COIL ON PLUG (COP) DESIGN
* Improved ignition coil position for improved energy transfers.
* The cylindrical coil can be installed in the plug hole, which was previously a “dead space”.
* Improved ignition coil position for reduced RFI/EMI.
* Improved packaging.
* Improved efficiency and output by reducing transmission length of high voltage to the spark plug.
* Improved efficiency and output by reducing problem prone connection points.
* Reduced noise output by reducing problem prone connection points.
Facts about Weapon X XCOP Ignition Coils
While the solid rope is better than the OEM spring style connector ours do not use either types. Because of these small interconnects the OEM coils are actually not really Coil On Plug (COP) they are really Coil Near Plug (CNP) setups. Our ignition coils for the 3V are a TRUE COP setup meaning that there is NO interconnect between the ignition coil and spark plug like the OEM design.
WeaponX uses a CNC profiled Copper and Zinc fitting attached to the end of the internals on our ignition coil which are friction fit to the spark plug like a standard spark plug connection. Our connector materials are also over 35X more conductive then stainless steel components and are also highly resistant to corrosion. They are also profiled so well that they are connected extremely tight to the spark plug itself and thus have very minor power losses through the connection unlike most competitors that use alternative methods.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
