*NEW PRODUCT* Whiteline Performance now @ Lethal Performance!
Lethal Performance is very excited to be teaming up with one of the most premier companies when it comes to handling and suspension components, Whiteline Performance!
Whiteline boasts a worldwide reputation as a leading manufacturer of replacement, enhancement and performance suspension components that deliver significant gains in vehicle balance, steering precision, grip levels and outright driving performance.
Consisting of adjustable sway bars (also known as Stabilizer Bars or Anti Roll Bars), chassis bracing, alignment products and chassis control bushing kits, Whiteline products provide automotive workshops, tuners, enthusiasts and racers with innovative solutions to suspension and handling problems while delivering proven performance & problem solving outcomes for many of the worlds vehicle platforms.
Check out the big buzz item for our S197 guys: Whiteline Performance 2005+ Mustang Watts Link Assembly
Looking to eliminate wheel hop? S197 customers, check out the Whiteline Performance 2005+ Mustang Rear Upper Control Arm and Mount
The S197 chassis third link set up has suffered from brake hop and axle tramp with the stock arm and the ultra-compliant stock bushing is designed for comfort and leaves something desired for performance driving. Whiteline’s upper control arm is built with 4130 Chromalloy and features the longer arm length which Ford incorporated in the 2011 change which reduces brake hop. The synthetic elastomer bushing adds increased stability to the rear end without the harshness of the commonly used bearing design and features and eccentric crush tube which allows pinion angle / instant center adjustment without weakening the arm with a turnbuckle adjustment. The pinhole voiding feature allows the bushing to articulate without binding. The heavy duty mount adds to the increased rigidity of the arm and is designed to be universal for all years of the S197 chassis.
Looking to equip your 05-10 with a Front Strut Tower Brace? Find Whiteline's high quality version here: Whiteline Performance 2005-2010 Mustang Strut Tower Brace
Whiteline Strut Tower Braces are made from dual tube 4130 Chromalloy and designed for maximum clearance under stock hood. They feature eccentric mounting points for further adjustment/clearance with aftermarket hoods.
There's an example of some of the high quality components Whiteline Performance is offering for our loyal customers. Give us a call if you have any questions, and equip your Mustang with these high quality suspension components from Whiteline Performance
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
