NEW: Lethal Performance 2007-2010 GT500 H Pipes IN STOCK!
Lethal Performance 07-2010 GT500 Offroad H-Pipe
Now in stock and ready to ship are the NEW Lethal Performance 07-2010 GT500 Offroad H-Pipes
You guys have been asking us for a long time for an affordable, well made H pipe. Lethal Performance finally brings you the answer.
Removing the cats has shown to increase power up to 30hp depending on your setup. Most important is that the stock cats won't hold up for long to the abuse of 700+rwhp. We've seen numerous times where a customers stock cats have failed and caused the car not to run properly. That's no more the case as our aluminized steel 2.5" offroad x-pipe simply removes the cats and lets your exhaust flow free. Our pipe is a direct bolt on and requires no welding or cutting. Just remove your stock midpipe from the exhaust manifolds and over axle pipes. Then install our pipe with the supplied hardware and you're done. Our pipe comes with the o2 sensor bungs welded in the stock location so there's no extensions needed. Tuning is required.
Featuring:
*Mandrel Bent Aluminized Steel*
*Offroad - No Cats*
*Bolts up to your Stock Manifolds and Over Axle Pipes*
*No Cutting or Welding Needed*
*Increased HP and Torque*
2.5" Diameter Tubing
*Hardware Included*
Pick up yours TODAY for $234.99, with FREE SHIPPING!
Contact us via Email, Live Chat, PM or call in between 9am-9pm EST by dialing 1-877-2LETHAL! Bolt on the H pipe you've always wanted for your GT500!
Featuring:
*Offroad - No Cats*
*Hardware Included*
inyadreems
08-21-2015 09:10 AM
