MilkJug removed
RE: MilkJug removed
I work for Ford and it cost over 300.00 for the airbox assy.But it does come with the mass air flow sensor,air filter,etc.
ORIGINAL: timmyisevil
how many of you guys removed that useless plastic pos, i bet if you went to ford to get one it would cost like 150 dollars
RE: MilkJug removed
I see what your saying,lucky for me i run a cold air intake,so my car doesnt use any of the stk airbox parts.I'm sure the stk setup works pretty good but i'm not sre where the water would go.
so whats the real reason for the milkjug and if the shaker is functional where does the water go when your driving in the rain ive always wondered that
RE: MilkJug removed
RE: MilkJug removed
There are multiple drains for incoming water- the first is on the shaker tray, then for water that gets inhaled by the shaker there is another drain at the bottom of the shaker scoop. Thats why there are those 2 hoses ziptied coming down from that area under the hood. And yeah that air silencer was the first thing to go- followed by the NVH 10lb paperweight bolted to the differential housing.
RE: MilkJug removed
NVH 10lb paperweight bolted to the differential housing. what did it do? does it just un bolt,maybe you should take a pic of it! so i can see what it is and take it off
Edit- sorry for some reason the picture isnt showing up.
