best mod's - MustangForums.com
Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Old 02-04-2008, 06:51 PM   #1
USMCrebel
Mach I Section Moderator
Default best mod's
Here Is a List of the Best mod's for under, and their Prices
**Bolt Ons**
Intake Spacer $100 (roy M1R#)
Catback $300
X-pipe $300
CAI $200
MGW $169
Aluminum DS $200
Accufab TB $350
L/T's * $400-700
Gears *
**Tuners**
Diablo Predator $319
SCT SF3/X3 $479
thats a list of all the mod's i could find to be fairly inexpensive and show some results on a dyno/ street, and that can be installed with average joe tools and in average joe time. with the singular exception being the long tube headers, from what i understand they're a bitch.
*= prices vary depending on maker.
# For all you guy's that are looking at getting Intake spacer (which i recommend) RoyC on here is the man to get it from. He will help you in every way possible, any questions and concerns you have he can help and will be more than willing to help. After receiving a bunch of PMs from Macher's and Non Mach 1 owners i thought it would be a good idea to get his contact info.
Any kind of spacer you need from 3/8-3" this is the man!
Roy
E-mail address is
wireguy2243@aol.com
USMCrebel is offline   Reply With Quote
Old 02-06-2008, 08:00 PM   #2
Mach1Fox
Default RE: best mod's
Excuse my ignorance, but what effect does the intake spacer have on performance?
Mach1Fox is offline   Reply With Quote
Old 02-06-2008, 08:47 PM   #3
Stone629
Stone629's Avatar
I've been trying to figure that out too. My guess (and it really is a guess) is that it reduces resriction in the intake manifold in some way. Porting makes sense because it is the process of removing any burrs or castings that may impede airflow, but the spacer doesn't really do that. Maybe it allows more air to be in the intake at a given time?
Stone629 is offline   Reply With Quote
Old 02-06-2008, 11:06 PM   #4
USMCrebel
this is going to be a very very rough explaination, but here it goes.
the intake on the mach is kinda crunched real close to the engine, and when the air goes in, it's really tight, and "restricted". So the intake spacer add's a gap so more air/ more cool air can flow in easier and thus becoming less of a restriction on the engine, and forcing the better air in allows for more hp/ tq to be achieved.... and it gives you better power thoughout the power band, so even though your peak gains aren't much, 4-7hp and 15-20 ftlb, this is an increase in the WHOLE rpm range.
wow i really butchered this with my limited understanding, but thats the kinda sorta way it works and what it does.
Old 02-06-2008, 11:14 PM   #5
Stone629
Stone629's Avatar
Makes sense to me.
Old 02-07-2008, 05:36 AM   #6
jmac72187
corner carver
jmac72187's Avatar
The biggest difference with the space is torque. It only makes about 5hp, but the torque gains are much higher.
jmac72187 is offline   Reply With Quote
Old 02-07-2008, 04:51 PM   #7
groundpounder
Sith Lord/Site Mod
groundpounder's Avatar
also, with a spacer there is a larger volume of air for the induction system to pull from, so when the injector pulse is mixed with the air coursing down the intake ports, there is also a slightly greater velocity to the charge. That's another part of the help
groundpounder is offline   Reply With Quote
Old 02-07-2008, 05:39 PM   #8
Mach1Fox
Can anyone recommend a place to buy one from? Also, do they come in different sizes, and if so, is there an optimal size?
Thanks
Old 02-07-2008, 05:48 PM   #9
USMCrebel
yes, there are any size you want, Roy on here just made a 3" one. he has advised me that a 3/8" spacer is optimal for the machs, and you want the largest one possible for the cobra.
Old 02-08-2008, 07:59 AM   #10
groundpounder
Sith Lord/Site Mod
PM RoyC. Says he's a newb - he ain't. He CNC's them himself. 3/8" is best unless you want to muck with your EGR. (like, eliminate it.)
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 06:23 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:29 AM
Plastic dip paint TimeLord101 New Member Area 2 10-01-2015 06:40 AM
When would you tune? firecoyote The New S550 2015-2017 Mustang 28 09-27-2015 02:37 PM
2003, car, chemistry, egr, inserts, intake, mach, mach1, plug, restrictor, roy, roys, sale, silencer, spacer
