New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-20-2008, 01:22 AM   #1
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
Default Mach Specs/ Info (basic rundown)
I figured it might be good to have these so any newcomers/ question askers know the basics of our car !
ENJOY!
Engine
MOD 4.6L DOHC V8 (Aluminum Block) Displacement 4.6L, 281 cu. in.
Horsepower @ rpm 305 @ 6000
Torque lb.-ft. @ rpm 320 @ 4250
Compression Ratio 10.1:1
Fuel System Sequential multi-port electronic fuel injection Fuel Requirement Premium (91 octane minimum)
Exhaust System Stainless steel with chromed rolled tips
Transmission Type 5-speed manual or 4-speed automatic
Final Drive Ratio 3.55:1 Gear Ratios (Manual) 1st - 3.38; 2nd - 2.00; 3rd - 1.32; 4th - 1.00; 5th - 0.62; Rev. - 3.38
Chassis Construction Unitized body Front Suspension Independent,
modified MacPherson strut with Separate spring on lower arm and stabilizer bar
Springs 600 lb Helical coil, rubber-insulated, unique linear rate Shock Absorbers Integral with Tokico strut, gas-pressurized, Hydraulic, unique valving Stabilizer Bar 26.5 mm (1.04 in.)
solid
Rear Suspension Four-bar link with coil springs on lower arm, unique horizontal axle damper and stabilizer bar Springs 250 lb Helical coil, rubber-insulated; unique linear rate Shock Absorbers Unique axle damper, gas-pressurized, hydraulic.
Vertical Tokico shock absorbers with horizontal axle dampers, unique valving
Stabilizer Bar 23 mm solid (.905 in.) solid Steering Power-assisted rack-and-pinion Overall Ratio 15.3:1 on center Turning Diameter,
Curb-to-Curb
38.1 ft. Brakes Front Calipers Aluminum dual piston, custom anodised painted Rotors 330 mm (13 in.) Brembo vented Rear Calipers Single piston Rotors 296 mm (11.7 in.) Brembo vented ABS/Traction Control Yes Pedals
(Interior Upgrade Package 18G)
Optional stainless steel pedal covers are positioned to provide better heel-to-toe relationship
Wheels 17 x 8-inch Magnum 500-style "Heritage Style" (5 spoke) Tires Goodyear 245/45ZR17 Eagle ZR45
Dimensions
Wheelbase 257.3 cm (101.3 in.) Overall Length 465.3 cm (183.2 in.) Overall Height 132.9 cm (52.35 in.) Overall Width 185.6 cm (73.1 in.) Tread Width (Front/Rear) [color="#000000"]152.9 cm (60.2 in.)/153.9 cm (60.6 in.) [/co
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is offline   Reply With Quote
Old 02-20-2008, 10:44 AM   #2
renegadeoffunk0
Default RE: Mach Specs
thanks for that
also, i would like to know who's foot they were using to measure this "better heel-to-toe" business as i have those pedal coversbut would have to completely mash down the brake pedal to maybe reach the accelerator with my heel.
__________________
Stock '03 Mach
renegadeoffunk0 is offline   Reply With Quote
Old 02-20-2008, 11:13 AM   #3
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
^ yeah, i tried it, and decided
1)their foot is broke
2)i think they drove a diffrent car, but i generally do it the other way, my heel on the brake and toe on the gas.
__________________
bone stock
Her name is Melanie
Old 02-20-2008, 11:27 AM   #4
renegadeoffunk0
you could always make some kind of modified shoe with a longer heel. or go to payless and raid the ladies' shoes [&:]
__________________
Stock '03 Mach
Old 02-21-2008, 04:15 PM   #5
DaMach04
Send a message via AIM to DaMach04
STICKY! STICKY!
__________________
Quote:
Originally Posted by AmericanMuscle4.6GT View Post
4 hot drunk freshman girls coming to my townhouse...
and its a girl to guy ratio of 3 to 1. they should be here any minute.
wish me luck fellas.
Quote:
Originally Posted by boostin95cobra View Post
and here you sit telling a bunch of guys on the internet...wonder why you are still a virgin...
DaMach04 is offline   Reply With Quote
Old 02-22-2008, 10:32 AM   #6
groundpounder
El Ass Bandito
done!
__________________
Quote:
Acer2428
If MF were a Disney movie, I'd be the retarded step-brother who eventually saves everyone by hitting the burgular over the head with a frying pan and then clapping my hands all retarded-like.
groundpounder is offline   Reply With Quote
Old 02-18-2009, 06:59 AM   #7
BIg FrEaK
Vehicle: '07 F150 Crew
Default Mach Prices
Great spec list at the top. Any idea what an '03 Mach goes for these days? I have been looking, but haven't found anything close to my price range ($4k right now, but saving + she won't be my DD, I can afford to fix her up )
BIg FrEaK is offline   Reply With Quote
Old 02-18-2009, 11:28 AM   #8
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
Quote:
I tell anyone who is looking, it is better to save up and have no payment than put yourself into a situation where you might not be able to afford it. Now with that out of the way..you can catch them from around 12-18k on average
__________________
bone stock
Her name is Melanie
Old 10-08-2009, 06:44 PM   #9
JDraper
JDraper's Avatar
Vehicle: 1966 Coupe, 2004 Mach 1
I can add some more specs to the sticky, although there are a few duplicates...
MACH 1
Front Suspension
Springs 600 lbs./in. linear
(lowers car ˝ in.)
Struts 35 mm piston Tokico Valve Shocks
Stabilizer Bar 26.5 mm (1.04 in.) solid
Rear Suspension
Springs 250 lbs./in. linear
(lowers car ˝ in.)
Shocks 30 mm piston, Tokico valve
Stabilizer Bar 23 mm (.905 in.) solid
8.8" 28 spline 3.55 Trac-Loc axle
Brakes
Front
Calipers Twin piston aluminum painted
Rear
Calipers Single Piston
Rotors 296mm (11.7 in.) Brembo vented
ABS and Traction Control
Subframe connectors
Engine
Engine Type MOD 4.6L DOHC V-8
Torque lb-ft. @ rpm 320 @ 4250
Bore and Stroke 90.2 mm x 90 mm
(3.55 in. x 3.54 in.)
Electronic fuel injection
Exhaust System Stainless steel with Chromed rolled tips
MPG CITY/HWY 17/25 (5-speed manual)
Transmission
Tremec 5 Speed
Gear Ratios 1st - 3.38; 2nd - 2.00; 3rd - 1.32; 4th - 1.00; 5th - 0.62; Rev. - 3.38
Dimensions
Tread Width (Front/Rear) 152.9 cm (60.2 in.)/153.9 cm (60.6 in.)
Curb Weight 3465 lbs. (manual) 3475 lbs. (automatic)
Front/Rear Seating Capacity 4
Aerodynamics Coefficient of Drag (Cd) 0.36
Luggage Capacity 10.9 cu. ft.
Passenger Volume 83.0 cu. ft.
Total Interior Volume 93.9 cu. ft.
Fuel Tank Capacity
15.7 gal.
__________________
'66 Coupe, '04 Mach 1, '05 F-150 SCrew, '08 Focus
JDraper is offline   Reply With Quote
Old 10-08-2009, 08:52 PM   #10
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
anything that help bring things to light stays!
__________________
bone stock
Her name is Melanie
250, damper, ford, gas, lb, list, mach, mustang, mustangs, rundown, sale, shock, specs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
