New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-18-2009, 12:15 AM   #11
EagleStroker
2007 Ford Mustang
EagleStroker's Avatar
Vehicle: 2007 Ford Mustang
Quote:
Originally Posted by 04AZUREBLUEMACH1 View Post
I was going to do a write-up, but I used programming software to write the code and a device programmer to put it on the chip. Unless you have access to these (I use them at work), they would far outweigh the cost of just buying the sequential taillights set from somewhere else.
I smell a side job...
__________________
"There are no traffic jams along the extra mile"
http://eaglerod.com/
EagleStroker is online now   Reply With Quote
Old 01-18-2009, 12:28 AM   #12
04AZUREBLUEMACH1
04AZUREBLUEMACH1's Avatar
Vehicle: 2004 Mach 1
Quote:
Yeah, I thought about that too... just don't have the time. Maybe when I retire in 40 years!
__________________
04AZUREBLUEMACH1 is offline   Reply With Quote
Old 01-18-2009, 12:33 AM   #13
EagleStroker
2007 Ford Mustang
It was worth a try man. Lemme know if you change your mind
__________________
Old 01-19-2009, 01:09 PM   #14
MACH5IVE
You should think about it! Cut back on your lunch about 10 minutes everyday to work on a set and you could easily add a couple hundred dollars to your monthly income... Im sure there would be quite a few guys on the forum willing to pay 50,60-70 bucks if they could just slice them in and go!
__________________
2004 Mach 1
It aint stock dammit!
MACH5IVE is offline   Reply With Quote
Old 01-19-2009, 06:41 PM   #15
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
cool...but you know what this makes you right? programming your own junk and all....AHEM NERD....that being said MOAR!!!!
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is offline   Reply With Quote
Old 01-24-2009, 10:52 AM   #16
uin2it
Vehicle: '03 Mach1 & '03 S/C Saleen
I know where to get them for $119.00
You could make and sell them for $75 and I'd buy a set!
uin2it is offline   Reply With Quote
Old 01-24-2009, 01:37 PM   #17
03MachMe
Vehicle: 2003 Mach 1
ill pay you 40 to make me one lol
__________________
2003 Mach 1
spec stage 2+ clutch
pro 5.0 shifter
K&N CAI
O/R H
Flows
FRPP 4.10 gears
8.2@83 1/8th
03MachMe is offline   Reply With Quote
Old 07-02-2009, 10:41 PM   #18
ecal533
2003 Ford Mustang Cobra
ecal533's Avatar
Vehicle: 2003, Ford, Mustang Cobra
I installed a set of these made by MustangTaillightSequencers.Com any only paid about $50. They are on Ebay. My complaint was that the flashed too fast and you really had to look at the tail light to tell what it was doing. The problem lied in both the cars turn signal flasher relay and the units I bought. After some testing the fix was easy and cheap. I bought a new flasher relay from the parts store and popped off the cover. There is a single capacitor that controls the speed of the flash. Typically the value is 4.7uf. With a solder wand I pulled that capacitor and installed a 6.8uf which you can order online or try radio shack. I gutted an old VCR. This simple mod slowed down the flashing to a more desirable speed.
Now I pulled the covers off my Sequencer Units to find 2 capacitors on each. Both had .47uf values. I increased all of them to a 1uf. This slowed down the sequencing rate down just enough to really get the effect. This was an easy fix and the only part to watch is making sure that when you resolder the caps back on the board that the (-) neg side is soldered the same way as the one you pulled off.
ecal533 is offline   Reply With Quote
12v, lights, made, sequential, tail, taillights
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
