well guys my bday is coming up
#51
as you've seen, it will run fine...but not the best it can. A good dyno tune will max out the efforts of mods and make it run better with more power across the curve. Results I've seen on dyno sheets are 15-30 hp.
#53
I went a couple months between my lt install and tune, no problems. But I was easy on the right foot, not wanting to cause any problems due to possibly affecting the airflow. You will be fine, btw what brand are you looking at? You may want to consider one where removal is not needed when needing to get to the transmission...I went with hooker which has this advantage.
Gary Ugarek
09-05-2015 09:03 PM
