Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-31-2009, 10:16 AM   #11
grif62
grif62's Avatar
Vehicle: 04 Mach 1
kooks or ARH, both good, getting ARH when I recover from surgery
__________________
04 mach 1, auto, magnaflow catback, o/r pacesetter h-pipe, sct tuner, JLT RAI, and saving for LT headers
grif62 is offline   Reply With Quote
Old 08-01-2009, 06:55 PM   #12
kweb288
1992 Ford Mustang
kweb288's Avatar
Vehicle: 1992, hatch
trust me i learned the hard way! buy the good stuff that will last the first time around!
O and headers arnt that hard to install yourself
__________________
Currently putting an 04 cobra engine in my fox http://www.mymustangproject1.webs.com
kweb288 is offline   Reply With Quote
Old 08-01-2009, 09:49 PM   #13
MTBer
Vehicle: 2004 Mach 1
Haha I can't tell you how many times I've bought crap first trying to save money and ended up buying the better stuff later
I have a cousin who is willing to port and polish my heads and port match them to headers if I decide to get them. Anyone have an idea of what gains I might see over just bolting on headers? Aside from that, I would be leaving the rest of the engine stock, and would have the following on the car when I consider it done-
port and polished heads port matched to Kooks longtube headers, PHP intake spacer, K&N intake, catted x-pipe, SLP catback exhaust, FRPP aluminum driveshaft, 3.73 gears, and SCT custom dyno tune. Maybe an Accufab throttle body. That would be it for power mods.
MTBer is offline   Reply With Quote
Old 08-17-2009, 02:56 AM   #14
BRIAN67SHELBY
BRIAN67SHELBY's Avatar
Vehicle: 2003 Mach1 mustang
Send a message via Yahoo to BRIAN67SHELBY
Talking
I waited and waited for the right price to pop up on ebay and I got a set of brand new SLP ceramic long tubes with matching off road x pipe for 600.00 shipped. I installed the x pipe with my original flowmaster 40's and it soundy a little too raspy for my taste. I went and purchased a new cat back system from magnaflow. It is the magnapack system which is a 2 1/2" mandrel bent pipes with straight thru design mufflers that are very simular to the Loud mouth II mufflers. That set up has a very deep tone to it which I liked very much until you really get on it above 3500 then it can get the neighborhood's attention very easily. I'm looking for the same sound that I had with my older 98GT(PI heads, custom cams, BBK LT, BBK O/R H-pipe, Flowmaster 40s w/turndowns), that setup was awsome in my opinion. It set off just about every car alarm within a 50 foot radius, because of the deep bass. I recently purchased a Pypes brand O/R H-pipe on ebay for around 110.00 shipped. I have a friend that works at a performance shop near the town that I live that is going to make a section of stainless pipe that we will use to mate the SLP long tubes to the Pypes H-pipe(H pipe is flared at the end and would require cutting to remove the flange mount). The SLP LT + O/R H pipe + magnapack will hopefully equal that ultimate sound that I've been striving for being a deep throaty muscle car sound. We will experiment with the setup to see if any increase or decrease in HP/Tq changes by switching the axle back pipes or going with dumps just behind the magnapacks. I've been told that the HP/torque numbers will increase at a lower rpm with H-pipes and that X-pipes will gain HP/tq numbers at higher rpms. Until I can get my cars weight down to 3200 lbs with me in it and a full tank, I believe that I will need the lower rpm HP/torque anyway.
__________________
Torch Red '03 Mach1 Natural Aspirated
C&L CAI tube
C&L 85MM MAF/ K&N
Acufab Twin 60mm TB
Meizier WP
Steeda underdrive pully w/2" shorter drive belt
3/8" Intake spacer
JMS SCT X3 custom tune
SLP 1 3/4" ceramic long tubes
PYPES O/R H-PIPE
Magnaflow Magnapack CAT-BACK
T56 w/26 spline input shaft
12 lb. Fidanza Aluminum Flywheel
Zoom 11" 2.5 Kevlar Clutch
Alum D/S
Pro 5.0 T56 shifter
3.55
329HP/380TQ PERFORMANCE CORNER, LLC DYNO GVW: 3608 w/driver, full tank
BRIAN67SHELBY is offline   Reply With Quote
Old 08-17-2009, 03:17 AM   #15
BRIAN67SHELBY
I will have the car dynoed with x pipe then with the h pipe and keep you posted on the difference based on the mods that I have now. I will try to see what the differences are when the dumps are added to each as well.
__________________
C&L CAI tube
C&L 85MM MAF/ K&N
Acufab Twin 60mm TB
Meizier WP
3/8" Intake spacer
PYPES O/R H-PIPE
Alum D/S
Pro 5.0 T56 shifter
3.55
Old 09-27-2009, 11:29 AM   #16
JDraper
JDraper's Avatar
Vehicle: 1966 Coupe, 2004 Mach 1
You can get there without the longtubes. I put down 302 hp/327 tq Standard corrected with a Borla Stinger cat back, C&L CAI, intake spacer, Meziere electric water pump, aluminum flywheel and a tune. My car is a 5 speed with a TMX2 computer code. I've added a Bassani catted X since the run, but haven't been back on the dyno yet.
BTW, dead stock I put down 269 hp/281 tq
Dyno sheet:
__________________
'66 Coupe, '04 Mach 1, '05 F-150 SCrew, '08 Focus
JDraper is offline   Reply With Quote
Old 09-27-2009, 06:36 PM   #17
MTBer
Dyno sheet:
Thanks, those are nice numbers.
Since I started this thread, my original Mach 1 was wrecked when an idiot in an F150 pulled out in front of me at a stop sign. I hit his front left tire doing 35mph. Both bags blew, but I walked away without a scratch.
Four days later, I bought another one though, and this one has Borla Stingers and a Bassani o/r X pipe. I plan on taking it to Livernois Motorsports next spring and getting Kooks longtubes, a catted X-pipe, 3.73 gears, and a tune. Before I take it down there I'll throw on an electric water pump and a FRPP aluminum driveshaft. I'm now aiming for 320hp/340ft-lbs at the wheels.
Old 09-27-2009, 08:06 PM   #18
JDraper
JDraper's Avatar
I'd avoid the 3.73's. Not much of a shift from 3.55's. If you want to change gears, go to 4.10's. Personally, if it's a stick, I don't think I'd change gears. I have enough problems getting my car to hook with the 3.55's even when I had the 315's on the rear. I know the auto Machs definitely benefit from the 4.10's though.
Since you're in Michigan, how about checking out MRT (Mustang Racing Technologies) for your parts/tuning? Scott Hoag, the owner of the company, was the designer behind the Mach 1 and the Bullitt when he worked for Ford. He's a great guy and knows these cars inside and out.
__________________
Old 09-27-2009, 08:57 PM   #19
mrtstang
Vehicle: 2004, Ford, Mustang Gt
+1...Scott did my gears, and i couldn't be happier! Good price and great customer service.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is offline   Reply With Quote
Old 09-28-2009, 10:35 AM   #20
Mustang3GT07
Mustang3GT07's Avatar
Vehicle: 2004, Ford, Mustang Cobra
Send a message via AIM to Mustang3GT07
I went with ARH longtubes over kooks because ARH have better ground clearance and are not a slip fit design like the kooks, which can leak at the collector sometimes.
__________________
2004 Cobra (Comp. Orange)
#3467 of 3768
-Tuned by Bob Kurgan
-485rwhp/506rwtq
2003 Ford Focus SVT
*Stock
2007 Mustang GT = Sold
2004 Mach1 = Sold
2001 Mustang GT = Sold
Mustang3GT07 is offline   Reply With Quote
23, car, gains, headers, horsepower, intake, kn, lok, longtubes, mach, mach1, php, reach, spacer, spacers, splines, traction
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
