Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-19-2009, 05:51 PM   #1
machalex
Vehicle: 2003 ford mustang mach 1
Default exhaust help please
i have bbk longtubes and off road h, with flows
i have 2.5in piping on the catback but i want to make it sound a little cleaner.
does the size piping help?
can i just weld in mufflers or should i get new catback.
what kind?
machalex is offline   Reply With Quote
Old 08-19-2009, 10:04 PM   #2
Fstanggt96
Vehicle: 2004 Mach 1
I would do magnaflow, not magnapacks, for a cleaner sound I think. A catted midpipe would also fix your problem most likely.
__________________
*ARH Longtubes + catted x-pipe and SCT tuner Here!!!*
04 Anny Mach 1 (Accufab Twin 60mm TB, drop in K&N, weld-in Flows)
96 Ford Mustang GT (sold 5/23/09)
88 Mustang GT 5.0 (sold 8/22/08)
91 Camaro RS (sold 7/25/08)
86 Nissan 4x4 (sold 3/15/07)
Fstanggt96 is offline   Reply With Quote
Old 08-20-2009, 03:11 AM   #3
BRIAN67SHELBY
BRIAN67SHELBY's Avatar
Vehicle: 2003 Mach1 mustang
Send a message via Yahoo to BRIAN67SHELBY
what kind?
I am set on Magnapacks, they have a deep, low rumble at idle, but at WOT, CAN YOU SAY NASCAR(at least that is what I think it sounds like when I go underneath a bridge, lol). But, that is with my SLP off road X-pipe. I am going to see how the modified H-pipe will sound very soon, I believe the UPS delivery date is on the 20th. I may go have it installed today if my friend at the shop isn't too tied up.
What do you mean by"sound a little cleaner" ? Do you have the stock cat-back or is it from flowmaster or aftermarket? I've heard that spintech has a little better sound than flowmaster if you still wanted to stick with a simular sized muffler. Spintech has a circlular pattern of baffles vs straight angles in the flowmaster. You can try this site to listen to certain exaust systems: http://www.mustangexhaust.com/
Is the exaust popping or backfiring during decelleration? Backfiring or popping may result due to too much unburned gas in the exaust. This can usually be fixed by doing a tuneup(new plugs, fuel filter, cleaning the air filter etc). I would go even as far as to check your O2 sensors. If those two things aren't the problem, send the car to a dyno and test the performance by adjusting the air/fuel ratio. Unless you're pumping out 500+ HP, your car needs that 2 1/2" pipe that allows for the correct back pressure to scavenge exaust fumes efficiently. If you go with a larger diameter pipe you would loose tq/hp.
I have the same year Mach1 and I am hoping this setup will work to give me a deep throaty muscle car sound: SLP 1 3/4" longtubes + O/R Pypes customized H-pipe + magnaflow magnapacks. I will be going with Comp Xtreme stage 2 cams with ported heads and intake when I come back from Iraq
__________________
Torch Red '03 Mach1 Natural Aspirated
C&L CAI tube
C&L 85MM MAF/ K&N
Acufab Twin 60mm TB
Meizier WP
Steeda underdrive pully w/2" shorter drive belt
3/8" Intake spacer
JMS SCT X3 custom tune
SLP 1 3/4" ceramic long tubes
PYPES O/R H-PIPE
Magnaflow Magnapack CAT-BACK
T56 w/26 spline input shaft
12 lb. Fidanza Aluminum Flywheel
Zoom 11" 2.5 Kevlar Clutch
Alum D/S
Pro 5.0 T56 shifter
3.55
329HP/380TQ PERFORMANCE CORNER, LLC DYNO GVW: 3608 w/driver, full tank
BRIAN67SHELBY is offline   Reply With Quote
Old 08-20-2009, 04:41 PM   #4
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
Flows are garbage lose em you'll be happier
USMCrebel is offline   Reply With Quote
Old 08-20-2009, 05:15 PM   #5
Subotai_95
Vehicle: 2004 Ford Mustang Mach 1
Quote:
Are you STILL being a grouchy bastard rebel? LOL sheesh..
mmeeehhh, I have to agree though, flows are pretty crappy.. the magna's I think are ok though I don't know why you'd want to clean up the sound.. 4v's are SUPPOSED to sound loud n' dirty.. :-D
__________________
04 Mach 1 w/ ATI P1 S/C-2 Inter-cooled, Brembo brakes/lines, SLP ceramic coated headers & Cat'd H-pipe w/LM2 exhaust, Nitto 555R 275/40 17's
Subotai_95 is offline   Reply With Quote
Old 08-21-2009, 12:30 AM   #6
blackGTcp
Any vids of your setup?
__________________
2004 Mach 1
blackGTcp is offline   Reply With Quote
Old 08-21-2009, 05:02 PM   #7
machalex
i dont but i can make a video and the flows just sound cheap....it sounds nasty at WOT but it sounds to dirty when cruising or at low rpms.
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
