Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2009, 09:17 PM   #1
Fstanggt96
Vehicle: 2004 Mach 1
Default My Mach makes wierd noises and is corroding...
Ok so I open the hood and start cleaning my engine bay (second time) and notice some white looking stuff on my throttle body. I take off my intake tube and its corroding in there!!! Wtf? Why? What should I do? What could it do to my engine? Car has 45k miles and has lived in kinda central (Puyallup/Tacoma) Washington its whole life. Also I have the common rearend whine, however, when I am coming to a stop in second gear I get this high pitched whiny noise and then I hit 1st and it gets louder and weirder. Still does it when the clutch is in... Is it my throwout bearing or something? Heres some pics/ videos...
Looks worse in person.
Videos in a minute...
__________________
*ARH Longtubes + catted x-pipe and SCT tuner Here!!!*
04 Anny Mach 1 (Accufab Twin 60mm TB, drop in K&N, weld-in Flows)
96 Ford Mustang GT (sold 5/23/09)
88 Mustang GT 5.0 (sold 8/22/08)
91 Camaro RS (sold 7/25/08)
86 Nissan 4x4 (sold 3/15/07)
Fstanggt96 is offline   Reply With Quote
Old 09-12-2009, 09:55 PM   #2
Fstanggt96
Videos uploaded. Turn the volume way up and listen at around 55 seconds on the first vid. I dont know if you will be able to here it? Ill try to find a better way to catch the noise. It really is quite load. Almost sound like im going fast in reverse.
__________________
Old 09-12-2009, 09:58 PM   #3
Fstanggt96
Wont let me post both for some reason... More videos in a minute.
__________________
Old 09-12-2009, 10:22 PM   #4
stang1101
does the car have aftermarket gears?
stang1101 is offline   Reply With Quote
Old 09-12-2009, 10:42 PM   #5
Fstanggt96
last one lol.
__________________
Old 09-12-2009, 10:43 PM   #6
Fstanggt96
Nope, stock. Has K&N drop in filter and 40 series flows... Could my Transmission fluid be low or something?
__________________
Old 09-13-2009, 02:11 PM   #7
stang1101
Quote:
Idk man. I don't have my Mach anymore, but I think I remember it doing the same thing. Should be fine.
Old 09-13-2009, 07:07 PM   #8
PaintballFreak
PaintballFreak's Avatar
Vehicle: 2004, Mach 1
The whining is just your transmission synchros spinning. When you down shift with the clutch pressed while coming to a stop you should hear them spin up as soon as the gear shift starts to enter the gate of the lower gear. They will spin up to get the transmission to meet the flywheel as smoothly as possible when the clutch engages (release pedal).
No worries it is normal. You need to worry when it makes a grinding noise with the clutch pedal depressed. That means your synchros are getting bent. Avoid this by rev matching with the gas pedal when you downshift and not power shifting
__________________
1999 GT - SOLD
2004 Mach 1 - Azure Blue
BBK Long Tubes - MAC O/R Prochamber - Borla Stingers
4.10s - Sniper Tuned
PaintballFreak is offline   Reply With Quote
Old 09-13-2009, 08:42 PM   #9
1sickmach
Vehicle: 03 Ford Mach 1 5 spd
i never noticed that with my car before and i have 87,000 on her,if your that concerned you could have it checked out ? when was the last time u had the fluid changed.
__________________
________________________
03 AZURE BLUE MACH 5 SPD:
JLT RAI:
PHP SPACER:
BASSANI X PIPE W/CATS:
MAGNAFLOW AFTER CAT:
390 GEARS:
MGW SHIFTER:
XCAL II W/CUSTOM TUNE:
MM SUSPENSION:
BILSTEIN HD STRUTS/SHOCKS:
350# FRONT COILOVERS:
CASTER/CAMBER PLATES:
FRONT LCA:
SWAY BAR END LINKS:
STERRING RACK BUSHINGS:
K MEMBER BRACE:
HD ADJUSTABLE LCA:
TORQUE ARM:
PANHARD BAR:
TORQUE ARM SPRINGS 375-440#'S:
SUB FRAME CONNECTORS:
18x9,18x10 CHROME BULLITT'S:
275/35,295/35 BFG KDW:
1sickmach is offline   Reply With Quote
Old 09-13-2009, 11:49 PM   #10
Fstanggt96
I might just change the fluid. Just changed the engine oil so its sensible. Paintballfreak you described it exactly how it is, I wont worry anymore however my 96 GT didn't do this... Oh well. Any word on why my throttle body has white s*** all over it lol? The first pic does the most justice, it looks that way inside there in person.
__________________
03, 05, clutch, depressed, grinding, mach, mustang, noses, pedal, pressed, transmission, whine, wierd
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
