Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-26-2009, 03:40 PM   #1
Justinr1001
Justinr1001's Avatar
Vehicle: 03 Mach 1
Default High RPM misfire.
I don't know whats going on, but my car has started popping and cracking at high rpms. Like 6600-6800, but it doesn't do it all the time. The check engine light is on because of some blow by, but it has been on way before it started doing this. The car has 85xxx miles on it. Any advice?
Justinr1001 is offline   Reply With Quote
Old 09-27-2009, 12:13 AM   #2
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
if i would've seen this before i got home i would've pm'd you and stopped by...i was up in your area this weekend.
lemme research it
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is online now   Reply With Quote
Old 09-27-2009, 04:17 AM   #3
Justinr1001
Vehicle: 03 Mach 1
Quote:
lemme research it
Dang, well thanks man. I have heard of misfires in the mach's before, but they said the check engine light would flash. Mine doesn't. I'm gonna change the plugs to some NGK iridiom's today and see if it helps. If not, i'll be back! lol
Old 09-28-2009, 03:03 PM   #4
04AZUREBLUEMACH1
04AZUREBLUEMACH1's Avatar
Vehicle: 2004 Mach 1
Default High RPM Misfire
My Check Engine Light flashes to indicate a misfire sometimes if I let the RPMs get up around 6500, so I just keep it under 6000.
I have about 106K on the clock and she has been very well taken care of.
__________________
04AZUREBLUEMACH1 is offline   Reply With Quote
Old 09-28-2009, 03:16 PM   #5
Derf00
Is this under a load (acceleration) the engine is having issues or if you sit idle and just rev it up?
Does the Battery light blink at the same time you notice the misfire?
Derf00 is offline   Reply With Quote
Old 09-28-2009, 08:52 PM   #6
Justinr1001
Vehicle: 03 Mach 1
Its just when its under load. I can be sitting and rev it and it does fine. It will studder for a second sometimes if i lay into it in 4th doing around 70ish. I haven't noticed the battery light blinking when it does it. Now that i think about it, the idle doesn't seem as smooth as it used to be.
Old 09-28-2009, 10:00 PM   #7
USMCrebel
2003 Ford Mustang
Vehicle: 03 Mach 1
get the Alternator checked for ****s and giggles, and do a reflash of the CPU
__________________
bone stock
Her name is Melanie
Old 09-28-2009, 10:24 PM   #8
Justinr1001
Vehicle: 03 Mach 1
It has a dyno tune. So i'd have to go back to them. But i will get the alt checked out just to see.
2000, 46l, 50, car, check, cyl, dohc, engine, ford, gear, gt, high, light, mach, misfire, misfires, mustang, rpm
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
