Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-04-2009, 01:54 AM   #11
Stone629
2009 Ford Mustang
My Garage
Stone629's Avatar
Vehicle: 2009, Ford, GT/CS
Cams can't be justified for most people. It gets costly replacing 4 of them. Heads, I wouldn't do that either. The stock heads are about as good as your going to get. I would focus on the suspension. If you're drag racing, then LCAs, adjustable shocks, poly bushings, etc. You might also want to consider getting some decent rubber out back. I know you're not hooking, lol! Losing some rotating mass as previously posted is a good idea too. Wheels, DS, all that stuff. Just depends on how much you want to spend and what your goals are.
__________________
2009 GT/CS, Vapor Silver, Manual '
308.4 RWHP/317.4 RWTQ
13.18 at 107 mph (2.0 60')...(1,243' DA, 75 degrees)
8.58 1/8th at 85 mph
2003 Mach 1, DSG, Manual
O/RX, Flowmaster Cat-back, weld-in subframes, KN Filter
13.1 at 107.97 Mph
Quote:
Originally Posted by SubTexel View Post
And when I win, I club a baby seal in front of the loser to let him know that it's his fault the baby seal died because he lost.
Stone629 is offline   Reply With Quote
Old 10-04-2009, 10:09 AM   #12
Sace
Sace's Avatar
thanks for all the feedback... im not into drag racing. besides going to the track here n there for kicks i drive it on sunny days basically. ive just always had somewhere else to go with the car.. exhaust intake tune gears etc.. now that its all done im trying to figure out where to blow money next lol. i have 315's outback already so that i dont need. i dont really want to set up the suspension to drag race because i dont do it enough. i guess i want more power!! procharger has been in works for a long time.. not sure if im ready to spend that kinda cash in one shot.. was just wanting other simple mods to help increase power but im starting to run out of ideas. the flywheel clutch driveshaft seems like a solid idea!
__________________
2003 torch redmach 1.
Exhaust, Tune, Intake, Shifter, Gears, Springs.
308rwhp/322rwtq
Sace is offline   Reply With Quote
Old 10-05-2009, 12:24 PM   #13
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
1)flywheel= lightweight
2)Alu DS
3)tubular K member = 30lbs saved
4)aluminum intake spacer
5) 4.10's
6)tune
you'll drop 50lbs and pick up ~15-20 HP or more, and with the lower reciprocating mass MPG won't suffer from the 4.10s
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is offline   Reply With Quote
Old 10-07-2009, 04:46 PM   #14
1sickmach
Vehicle: 03 Ford Mach 1 5 spd
I would do the suspension, i use MM but there are others that are good to.
__________________
________________________
03 AZURE BLUE MACH 5 SPD:
JLT RAI:
PHP SPACER:
BASSANI X PIPE W/CATS:
MAGNAFLOW AFTER CAT:
390 GEARS:
MGW SHIFTER:
XCAL II W/CUSTOM TUNE:
MM SUSPENSION:
BILSTEIN HD STRUTS/SHOCKS:
350# FRONT COILOVERS:
CASTER/CAMBER PLATES:
FRONT LCA:
SWAY BAR END LINKS:
STERRING RACK BUSHINGS:
K MEMBER BRACE:
HD ADJUSTABLE LCA:
TORQUE ARM:
PANHARD BAR:
TORQUE ARM SPRINGS 375-440#'S:
SUB FRAME CONNECTORS:
18x9,18x10 CHROME BULLITT'S:
275/35,295/35 BFG KDW:
1sickmach is offline   Reply With Quote
2003, 2004, 46, 98, coils, forum, gt, mach, mods, mustang, run, sohc
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
