Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Mach 1 Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 06:17 AM   #1
cwf340
2004 Ford Mustang
Vehicle: 2004 Ford Mustang Mach1
Default cat back, ring and pinion question.
hey all, Im getting a stock 04 mach 1 tomorrow errr later today.. And Im excited to start bolting on goodies!! I think I want to use either a SLP powerflo or the JBA cat back system first. Which one should I go with? I want it loud but without the droan noise through the floor. or at least the one the has the least droan. I also want to go with 4.10 gears, which brand should I go with? I have installed richmond gears and motorsport gears in cars and ended up with gear whine, do the motive gears whine? also will the H pipe for a GT fit the mach1? which brand fits best? Thanks in advance for any advice! Heres a shot of the car!
cwf340 is offline   Reply With Quote
Old 10-23-2009, 08:29 AM   #2
mrtstang
Vehicle: 2004, Ford, Mustang Gt
Welcome to the forums! If you want minimal drone then you don't want a chambered muffler in general. Also, neither of those mufflers will be very loud. I would consider something like Stingers, Magnapacks, LM 2's, SSS Terminator's, etc, if you want loud with little drone. These are straight throught style mufflers, and tend to resinate less (depends on the rest of the exhaust though) than chambered mufflers.
An h pipe for a gt will fit a Mach 1 as well. The best (also most expensive) would be MRT in terms of fitment and quality.
I have Motive gears, and mine wine just a little, but barely noticable. Your best bet would probably be Ford Racing gears.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is online now   Reply With Quote
Old 10-23-2009, 11:54 AM   #3
XxMustangManiacxX
XxMustangManiacxX's Avatar
Vehicle: 03 Ford Mustang Mach 1
Send a message via AIM to XxMustangManiacxX
First of all congrats man! and that is a very sexy mach!
If i was you i would put SLP lm1's or 2's
and definitely! definitely definitely definitely get Ford racing Gears!
Slp and Magnaflow have great Midpipes and if you decide to do straight through pipes (slp) then look to get a xpipe...thats my opinion but its your car and your money so go on youtube and such and figure out what suits you best
__________________
03 DSG Mach 1 5spd
~SLP Lm1's
~Roys intake spacer
~Fiore clutch quadrant + Firewall adjuster
~ few exterior mods
XxMustangManiacxX is offline   Reply With Quote
Old 10-23-2009, 03:43 PM   #4
JDraper
JDraper's Avatar
Vehicle: 1966 Coupe, 2004 Mach 1
Congrats on getting a Mach!!
If the car is a 5 speed, you might not want to put 4:10's in it. With the ratio's in the 3650 and the power they put down, 4:10's would make 1st gear almost useless. I have mild mods on my Mach with the stock 3.55's and, even when I was on 315's I couldn't go full throttle in first without roasting the tires. If you run DR's you can get it to hook, but then you better upgrade the rear and reinforce the torque boxes so you don't bust something.
__________________
'66 Coupe, '04 Mach 1, '05 F-150 SCrew, '08 Focus
JDraper is offline   Reply With Quote
Old 10-23-2009, 04:43 PM   #5
rygi23
rygi23's Avatar
Vehicle: 04 Mach 1
Check out the "Mach 1 Exhaust Notes" sticky. Take note of how much sound midpipes add. With stock midpipe, louder muffs/ with aftermarker midpipe, quieter muffs (they'll still be just as loud). Don't make my mistake and get a loud straight-through resonator (I have SLP LM1s) and try to run no cats...toooooo loud. Get what sounds good to you, that's all there is to it.
Gear whine is a result of the install. It's almost luck of the draw. People who've installed hundreds of them will tell you that when you're dealing with a matter of thousandths of an inch you can only be so perfect. I say go only with FRPP though. 4.10s are awesome. Good amount of clutch work at the track to get her to hook but you have to do that with 3.55s anyhow. Even with DRs you can't dump it anyhow with 4.10s because you'll bog a little (why I wish I'd gone w/ 4.30s or 4.56s). That's my experience anyhow. That's all I have to say about that. Sweet find brother, you'll love it.
__________________
rygi23 is offline   Reply With Quote
Old 10-23-2009, 06:22 PM   #6
darkmach1
darkmach1's Avatar
Congrats on the mach. Go with the basics intake/exhaust/tune/gears, then you can see where you want to go from there. As far as exhaust, I cant tell you how happy I am with my SSS adrenalines, you can always move on to the terminators if you want louder. For me, the adrenalines are nice and quiet when driving normal but since its a straght-thru design it screams on wide open throttle. Check out the exhaust notes sticky, good info and sound clips there.
__________________
Mods: C&L intake, Mac prochamber, Moser 31 spline axles, FRPP trac-lok, FRPP 4.10s, Steeda Tri-ax short shifter, SSS catback, PHP 3/8 intake spacer, VMP custom tune(SCT).
....I foresee a squeaky belt in my future.....
darkmach1 is offline   Reply With Quote
Old 10-23-2009, 09:23 PM   #7
1sickmach
Vehicle: 03 Ford Mach 1 5 spd
I have Magnaflows not the packs,and they sound good just not loud enough so for my self it will be either the Bassani race or the SSS Terminator.As far as gears 410's would be a good balance between street/ strip and open track,and no 1st gear is not useless i have had 410's and people will also tell you that you can't drive a car with 410's in the rain again B.S. you will be fine.
__________________
________________________
03 AZURE BLUE MACH 5 SPD:
JLT RAI:
PHP SPACER:
BASSANI X PIPE W/CATS:
MAGNAFLOW AFTER CAT:
390 GEARS:
MGW SHIFTER:
XCAL II W/CUSTOM TUNE:
MM SUSPENSION:
BILSTEIN HD STRUTS/SHOCKS:
350# FRONT COILOVERS:
CASTER/CAMBER PLATES:
FRONT LCA:
SWAY BAR END LINKS:
STERRING RACK BUSHINGS:
K MEMBER BRACE:
HD ADJUSTABLE LCA:
TORQUE ARM:
PANHARD BAR:
TORQUE ARM SPRINGS 375-440#'S:
SUB FRAME CONNECTORS:
18x9,18x10 CHROME BULLITT'S:
275/35,295/35 BFG KDW:
1sickmach is offline   Reply With Quote
Old 10-23-2009, 09:28 PM   #8
1sickmach
Even though i like to do an open track event or 2 a year nothing serious and my car is set up for this,i will be going with 430's shortly.
__________________
JLT RAI:
PHP SPACER:
390 GEARS:
MGW SHIFTER:
MM SUSPENSION:
FRONT LCA:
SWAY BAR END LINKS:
K MEMBER BRACE:
HD ADJUSTABLE LCA:
TORQUE ARM:
PANHARD BAR:
Old 10-23-2009, 10:29 PM   #9
USMCrebel
Mach I Section Moderator
2003 Ford Mustang
Vehicle: 03 Mach 1
SSS catback is the best sounding out there, maybe i'll do an Xpipe eventually.
__________________
2003 Ox Wht Mach 1 1:814
bone stock
Her name is Melanie
USMCrebel is offline   Reply With Quote
Old 10-23-2009, 10:35 PM   #10
mrtstang
^^^just don't do a o/r x with the SSS Terminators unless you like it insanely loud! I've been there and done that lol.
__________________
lm1, midpipe, slp
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
