It's a crap shoot at best, with very little power to be gained, and a good way to blow the engine. Without going into a whole lot of details, the use of an underdrive crank pulley can cause increased harmonics (vibrations), that can crack the cast gearing on the oil pump resulting in catastrophic engine failure.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2003 Torch Red Ford Mustang Mach 1 5-speed 527.52 RWHP 495.15 RWTQ @16lbs. on 93 Octane
So I clay bared the car today and applied a fresh coat of wax. I figured I'd try to wax the hood stripe since it was already messed up anyway, and I had nothing to lose.
Turns out applying a new coat of wax and wiping it off helped a lot. Most of the swirls and old dried wax seems to have disappeared. Still ordered a new stripe anyway, but it did help a lot.
I've seen a couple Machs that had the stripes painted on. Looks really good and last much longer. Just cost much more.
About those pulleys. I've heard many conflicting opinions on that one. I won't ever do them just because it has supposedly caused failures, but a Tech at my tuner told me that the reason they mess up is because people don't know what they are doing when they install them, or get POS pulleys. He said that if they are done right, that they are a great, safe mod. He's been a Ford Tech for 15 years and has been working for this tuner for a few years now. I still wouldn't risk it.
__________________
2009 GT/CS, Vapor Silver, Manual '
308.4 RWHP/317.4 RWTQ
13.18 at 107 mph (2.0 60')...(1,243' DA, 75 degrees)
8.58 1/8th at 85 mph
ok sorry to break hearts but the JLT ram air intake i bought WILL NOT work... the 90 degree elbow is the same size as the pipe.... the company is kinda a pain in the ass to replace it... anyone else had this problem...
and i have slp loudmouths on my mach.. i think it sounds great... couldnt think of a better tone for the car
So you're saying it isn't working as advertised, or that it just won't install right?
Either way that's a bit disappointing, I really wanted to keep my shaker functional. Steeda also makes a kit but it's a bit more expensive and claims weaker results.
New stripes seems like the best option for sure. Painted-even better IMO. Until then try to revive them a little with Turtle Wax ICE wax. It helped mine and they look as good as new now.
__________________
2003 Mach 1
Azure Blue, Mostly Stock, Flowmasters, AR Torq Thrust M's, auto, Daily Driver, Love it!
