Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
***DM1's Eaton swap build*** all eaton stuff in here
Old 11-22-2009, 03:15 PM
darkmach1
darkmach1's Avatar
Default ***DM1's Eaton swap build*** all eaton stuff in here
424whp/381wtq on a MustangDyno w/14* timing @8psi
--MAIN PARTS--
• Supercharger with stock pulley
• Lower intake
• Intercooler
• Water manifold with nipples
• Throttle body with plenum
• 39 lb. injectors
• Vacuum actuator w/attaching hardware
• EGR valve – new straight plug IAC – w/attaching hardware
• EGR sensor bracket
• EGR riser tube
• Accelerator cable with bracket and attaching hardware
• MAF housing
• IAT 2 / BARO sensor w/ attaching hardware
• Timing chain cover - new
• Cross tube w/sender
• Main pulley bridge w/tensioner and idlers
• Alternator idler bracket
• Used alternator
• Both alternator to block bracket
• Harmonic balancer
• Lower caged charger pulley with idler
• Intercooler pump with bracket
• Intercooler reservoir
• Heat exchanger lines
• Hard intercooler line at block
• Heat exchanger brackets
• Heat exchanger
• Long heat exchanger lines
• Heat exchanger engine hard lines and hoses
• P/S bracket
• Belt engine cover
• Air intake to MAF housing
• Long upper cross tube hose
• Upper radiator hose
• Blower belt
• Accessory belt
--GASKETS--
• Water manifold nipple O-rings (2 packages)
• Charger to lower
• Water manifold to lower
• Throttle body to plenum
• Plenum to charger
• Timing cover gasket
• Intake gasket not in stock
• Front crank seal
--HOSES--
• Oil cooler to T-housing
• T-housing to radiator
• T-housing to reservoir
--MISC--
• Power steering return line
• Oil cooler set
• Accessory tensioner
• MAF sensor
• Adapting pigtails for alternator, intercooler pump, and IAT2 sensor
--UPGRADES--
• 03/04 cobra tank/pumps setup.
• LFP extreme dual pass H/E and the LFP cooling mod which can be installed through the front of the car....
• Innovative lc-1 wideband, sport comp 2 boost gauge and SOS pillar pod.
IN PROGRESS
FINISHED PRODUCT
VID...
http://www.youtube.com/watch?v=__2sEF1da0k
darkmach1 is offline
Old 11-22-2009, 03:40 PM
Stone629
Stone629's Avatar
What happened man? The pics have been removed.
Stone629 is offline
Old 11-22-2009, 04:15 PM
darkmach1
darkmach1's Avatar
I was resizing, they should be up now.
Old 11-22-2009, 04:17 PM
Stone629
Stone629's Avatar
Oh snap! It did just get serious. When is it going on the car?
Stone629 is offline
Old 11-22-2009, 04:27 PM
darkmach1
darkmach1's Avatar
Yes it did. Not sure when its going in, I'm waiting for a buddy of mine to contact his buddy which does a lot of work on cobras so he can get me a cobra fuel tank, pump and duel pass heat exchanger(I have the stock one, but cooler is always better, especially in south florida). Also, am still missing small stuff like gaskets, pigtails and oil cooler.
Old 11-22-2009, 04:34 PM
Stone629
Stone629's Avatar
Any idea how much boost you're going to run?
Stone629 is offline
Old 11-22-2009, 04:36 PM
rygi23
rygi23's Avatar
Wow! Congrats, man. My living room's looking similar with headers, x pipe, clutch and cams sitting around but you got the big mama jama sittin there! You building the motor for it or gonna keep the psi reasonable?
rygi23 is offline
Old 11-22-2009, 04:59 PM
johnr2001gt
johnr2001gt's Avatar
you will love it for sure................
johnr2001gt is offline
Old 11-22-2009, 05:16 PM
I G Joe
I G Joe's Avatar
hope you have forged internals!
I G Joe is offline
Old 11-22-2009, 05:30 PM
darkmach1
darkmach1's Avatar
Stock pulley, ~8 psi.
LOL yea I didn't think there was gonna be so many boxes, total weight was 190lbs. Im gonna keep the boost reasonable, I'm happy with 400-415whp, which "should" be ok on the stock shortblock. I don't race a whole lot, all my friends tell me I should beat on the car more, most if not all of my driving is in the highway at around 60mph.
yea, especially with 4.10s, LOL.
I'm not worried, if needed, the funds are there and then some.
Quick Reply: ***DM1's Eaton swap build*** all eaton stuff in here
