Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Brake calipers: Should I paint?
Old 05-31-2010, 08:13 PM
hpwrestler220
hpwrestler220's Avatar
PAINT THE CALIPERS... It will not flake off if you do it correctly.. Sand it down to scuff it all up, wipe it off and clean it, and apply a couple coats of paint. I am a BIG advocate of simple spray canning it, but brush on works well if you would rather that...
Eventually it may flake off due to rocks getting kicked around and such, but thats normal. Just apply another coat if they start flaking...
Painting > OEM mach 1's... paint them all the way.
/thread
hpwrestler220 is offline
Old 05-31-2010, 10:31 PM
MustangMan00
MustangMan00's Avatar
we painted my friends azure blue mach with azure blue paint we had mixed at carquest for ~$25 for 2 cans
matched perfectly, no fade/adverse affects
cliffs...DO IT
MustangMan00 is offline
Old 06-03-2010, 07:21 PM
machracer11
machracer11's Avatar
Painted mine the duplicolor blue and they look amazing... and if you do it right then they will stand up great
machracer11 is offline
Old 06-04-2010, 12:56 AM
Fstanggt96
Fstanggt96's Avatar
Dont know how you guys are painting them, but I work at Discount tires(3 years) and every set of painted brakes I have seen look like absolute ****(or atleast I dont remember a set that looked good). If you dont keep up on them, you will regret it I think.
Fstanggt96 is offline
Old 06-04-2010, 07:17 AM
machracer11
I painted mine by the directions that came with the kit, didnt cut any corners, and they are still just as blue as they were when i finished them up two years ago
Old 06-04-2010, 06:22 PM
hpwrestler220
Sand em and clean em off good. Apply a couple coats. and clear them if you are feelin crazy. They will hold up
Just think how many rocks and such get kicked up around in there... The only alternative to painting is powdercoating. But painting = $10 and powdercoating = $100+
Paint them. If it comes out sh*tty, resand them and do it better haha. You cant really go wrong here... Everything can be fixed and anything will probably look better than what they are now
Matt's 95 Stang
10-05-2015 07:16 AM
10-01-2015 09:29 AM
GLOCKer
09-28-2015 07:36 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake calipers: Should I paint?
