Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Is this transmission compatible?
Old 01-31-2011, 09:17 PM
saleenkill
saleenkill's Avatar
Default Is this transmission compatible?
I have a 2002 Mustang GT with a 4R70W Transmission that is dying, I found a 03 Mach 1 4R70W Transmission on ebay. And I thought auto Mach 1's came with the 4R75W not the 4R70W. I have searched around on the forums and some people say yes it is a direct swap and some say no. I emailed the guy and he said it is supposed to be a 4r70W from a 2003 Mach 1.So 2 questions, Is it a direct swap and did the 2003 Mach 1 come with a 4R70W? Here is the link..http://cgi.ebay.com/ebaymotors/2003-...item2a0d8d4fce
Thank-you for your help.
saleenkill is offline
Old 02-01-2011, 08:06 PM
rygi23
rygi23's Avatar
http://www.nzmustang.com/newmustangs/2003mach1.htm
"To handle the 4-valve’s power, the 4R70W automatic transmission is upgraded with a heavy-duty gear-set, auxiliary fluid cooler, and brazed 11.25-inch torque converter"
The only other things I can think of is that the gearing may be a little different and shiftpoints may need to be adjusted with a tuner. With some research on those points I think you can certainly make it work.
rygi23 is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
junior04
09-28-2015 10:53 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Is this transmission compatible?
