Transmission problem maybe?
Hey guys it has been a while.
I noticed a problem when I drive above 60mph, it can range from 60-90, and let off the gas my rpm hangs for a little bit and then drops and it repeats this cycle until it reaches below 60 mph. I think it may be a transmission problem, but I also think it may have to do with the overdrive gear. I would like to know what you guys think about this.
It does sound like an OD problem. If it is, it would be far from the 1st OD to go in an auto. I've heard a bunch of stuff about how the OD is the weak link in the trans. Not that they go quick, but if something does go it's usually that. But who knows, be easy on it for a few days and see if you can definitivly narrow the problem down. Good luck with it man.
