Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Maintenance on Mach?
Old 04-11-2012, 05:40 PM
grif62
grif62's Avatar
Default Maintenance on Mach?
Hey guys, my mach just hit 45k miles and my question to you guys is what maintenance should I be considering for the mach? Like transmission refill, coolant change, or differentials and etc. I would like to know what I have to do to keep the mach up in proper form.
grif62 is offline
Old 04-11-2012, 08:35 PM
dmostz
dmostz's Avatar
Glad you posted this, I was wondering the same. Going to PM you in a minute about your setup, hope you dont mind.
dmostz is offline
Old 04-16-2012, 10:34 PM
grif62
grif62's Avatar
bump?
grif62 is offline
Old 04-17-2012, 09:10 AM
jimmy428
jimmy428's Avatar
my mach just hit 50k not too long ago. i did the following just for peace of mind:
oil and filter change
spark plug change
trans oil and filter change
new gas filter
diff oil change
jimmy428 is offline
Old 05-04-2012, 04:38 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
im due for my next round of maintenance at 90k now.
at 50k I did
Brakes
Plugs
Fluids
Filters
Shocks/Struts
Going to do it again as i get the time/ money...starting with brakes first so i don't kill me or others lol.
USMCrebel is offline
Old 05-04-2012, 05:02 PM
Old Mustanger
Old Mustanger's Avatar
spark plug change
new gas filter
diff oil change
That is a good to change the fluids, most people forget about them
50K is a good time to switch to synthetics too.
Old Mustanger is offline
Old 06-11-2012, 07:04 PM
jkmach1
jkmach1's Avatar
i have the 03 mach 1 and i was wondering how do u get the services engine soon light off? Can someone let me know
jkmach1 is offline
Old 06-30-2013, 08:53 PM
tomcat5157
tomcat5157's Avatar
well first and foremost find out why the light is there and fix it! and then after all is said and done disconnect the battery for about 10 seconds hook it back up then it should be gone! or get a tuner that can clear codes.
tomcat5157 is offline
Old 07-01-2013, 12:59 AM
Sonic Mustang
Banned
Sonic Mustang's Avatar
Nobody ever thinks about FLUSHING THE BRAKE FLUID. Ford doesn't even spec a flush interval in the mustang service manual. Why? Our cars do not have lifetime brake fluid. According to a post by an ex-Ford friction test engineer, FoMoCo figures the car will be totaled or the brake components will have to be serviced forcing a refill before it gets really bad.
If you want to scare yourself, flush the old fluid out of a nine year old car.
Brake fluid absorbs moisture from the air. Water boils into steam and compresses under pressure. That's why brakes get spongy. Moisture also promotes corrosion of brake parts. Fluid absorbs moisture whether the car is parked or moving, so change brake fluid based on time.
Typical DOT 3 fluid is good for two years. The best performing fluid for street use is Ate Super Blue or Typ 200 DOT 3/4 which easily lasts 50% longer.
According to an engineer I spoke with at Continental-Teeves, Ate Super Blue doesn't absorb less moisture than regular fluid, but it holds in in suspension much better.
The factory interval for fuel filter replacement is 30K.
The coolant interval is 7 years / 100K. There is a specific procedure for refilling your Mach's cooling system. If you don't follow it exactly, you will have air in the system and overheat.
I don't know anybody who actually has pulled the block drain plugs, but you should at least drain then system at the thermostat housing and refill with Ford Gold Coolant mixed 50/50 with distilled water. Follow this procedure EXACTLY: http://reischeperformance.com/refill.html
Sonic Mustang is offline
Old 07-01-2013, 01:25 AM
DocSnickers
DocSnickers's Avatar
FoMoCo figures the car will be totaled....
I bet this happens a lot more than one thinks. Getting all those young stallions behind the wheel that think they are hot ****. Then hit a tree, or a parked car trying to show off.
DocSnickers is offline
Quick Reply: Maintenance on Mach?
