Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Problem with rear tires catching the inside of the fender
Old 05-03-2012, 04:01 PM
Blood
Blood's Avatar
Default Problem with rear tires catching the inside of the fender
So I have had this problem for a while, whn I hit a bump the sharp side of the inside of the fender catches my tire and has put some mean slices in my tires... I got a bat and rolled back the fender on the inside that lip a little bit, but still does it when I hit a big bump. I only have 275/45/18 on the rear, I wanna go 295/35/18 soon...
Whats the best solution to fix this? I do have about a 1-1.5" drop on the whole car eibach lowering kit. Any advice or who has had this problem before? its a Mach 1 04
Blood is offline
Old 05-03-2012, 08:12 PM
djoneill
djoneill's Avatar
http://www.eastwood.com/ew-fender-ro...struction.html
You can rent on some forums.
djoneill is offline
Old 05-03-2012, 08:35 PM
HamMach1
HamMach1's Avatar
What djoneill said. Rent an Eastwood fender roller and roller your fenders! I still need to do mine
HamMach1 is offline
Old 05-04-2012, 09:27 AM
Blood
Blood's Avatar
Where would I rentt his from?
Blood is offline
Old 05-04-2012, 01:46 PM
HamMach1
HamMach1's Avatar
That website
HamMach1 is offline
Old 05-06-2012, 02:51 PM
Blood
Blood's Avatar
I dont see where it says I can rent it. Just see buy for 200+ $$$!
Blood is offline
Old 05-09-2012, 11:10 PM
Repzard
Repzard's Avatar
@OP I just opened a similar thread but my bud doesnt want to roll fenders.
His tires are 315-35-17 and is having the same problem and your tires are a smaller profile.
Whats with the rubbing issues on the Mach1?
My 99 GT even lower than stock Mach1 height and have no rubbing issues with this size rim and tire.
I find this to be odd.
Repzard is offline
Old 05-10-2012, 10:46 AM
Blood
Blood's Avatar
Hmm idk... But I cant find a way to roll them. ANd cant find wher eto rent that machine.
Blood is offline
Old 05-25-2012, 07:29 PM
Blood
Blood's Avatar
Bump any idea how to rent this? really need it.
Blood is offline
Old 05-26-2012, 09:56 AM
Old Mustanger
Old Mustanger's Avatar
Do you still have the stock panhard bar on the car?
Measure the clearances on the inside wall to metal and compare to outside.
It most likely sounds to me like your rims have the wrong offset for your particular use.
Rolling the fender lips will definitely help your situation.
Old Mustanger is offline
Quick Reply: Problem with rear tires catching the inside of the fender
