no more fuel to the motor - MustangForums.com
Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Old 02-22-2014, 07:37 PM   #1
dubarado
dubarado's Avatar
Unhappy no more fuel to the motor
Well I was out in the Mach for a cruise today in this nice weather, and What started as a normal drive ended in a flatbed ride home. I was leaving a light and rolled onto the throttle in 2nd gear, and as I slowed to the next light it started to rough idle. Then it cut out completely. I restarted it and was flooring the pedal trying to get fuel into it and managed to get enough speed to pull off to a side road where it died again. Knowing the battery was 4 years old, I swapped it on site after my brother in law brought one out, and it starting turning over really well, but no fuel! I checked the fuse, it was good, the cutoff in the trunk was not popped up but i reset it anyways (tapped it til it popped then pushed it back down. I also depressed the valve on the fuel rail and no gas came out. Leading me to think it's the pump. Anyone else think it's the pump? What else should I check before dropping the tank? There were/are no codes since I swapped batteries.
Thanks!
dubarado is offline   Reply With Quote
Old 02-22-2014, 10:21 PM   #2
cema93
Well if there's no gas coming out of the fuel rail then that means there's either a blockage or the fuel pump isn't priming/running. And u said it wasn't a fuse. U have already narrowed it down it sounds like. I'd be willing to bet its the pump. Not much else it could be, right?
cema93 is offline   Reply With Quote
Old 02-23-2014, 11:38 AM   #3
dubarado
dubarado's Avatar
Yes I checked the switch in the trunk and its getting power. Had my buddy stand behind the car and didnt hear the pump, so needless to say I gotta drop the tank to swap it. Any tips or tricks for this? Also what's a good fuel pump? Autozone is cost effective, but not sure if the walbro/airtex pumps are decent. See a lot of mixed reviews.
Old 09-06-2014, 04:25 PM   #4
dubarado
dubarado's Avatar
Oh, forgot all about this post, but I installed a green top SVT focus pump and she's been running well ever since (knock on wood)
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2016 Mustang 15 06-23-2016 06:26 PM
built help EASTIDEE123 5.0L (1979-1995) Mustang 14 09-14-2015 04:52 PM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 11:29 AM
Will not fire up Wombatnation 5.0L (1979-1995) Mustang 12 09-13-2015 10:16 PM
85 5.0 with stock holley calif. carb tramphardrocker 5.0L (1979-1995) Mustang 6 09-13-2015 09:56 PM
