Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
hard clutch.
Old 11-30-2016, 01:14 PM
Rick Gonzalez
Rick Gonzalez's Avatar
Default Cluttch
Thanks alot.....very helpful....my first Mach 1 had 68,000 when I bought it & obviously had clutch issues , but the one I'm getting next week only has 13,500 miles & one owner....should be fine
Rick Gonzalez is offline
Old 11-30-2016, 03:48 PM
Rick Gonzalez
Default 2003 Mach 1
Fine with me....wanted one with low mileage to avoid any clutch issues.....should drive & shift like new
Old 11-30-2016, 10:38 PM
Z28KLR
Z28KLR's Avatar
The stock clutches on these cars are already a little heavy on effort required, unlike the '05+ S197 platform cars that use hydraulic assist (as do most other modern cars since about 1985) when you push the pedal on these cars you are directly fighting with the pressure plate. Adding any sort of "performance" oriented clutch setup generally results in increased effort.
Unless it seems like it's binding - hitting a hard spot somewhere midway thru pedal travel or there are any sort of engagement/disengagement issues, heavy pedal effort (as compared to most other cars) is pretty normal.
Z28KLR is offline
Old 11-30-2016, 10:53 PM
Rick Gonzalez
I decided to try one more of these Mach1;s....this time one owner & 13,500 miles on it.....should be like new....I have heard different opinions but my first 2003 Mach 5 years ago had 68,000 on it when I bought it & the clutch seemed way too hard.....possibly changed , worn out , cable issue...who knows...but I will try this one next week when it is delivered & hopefully will be impressed....I dont mind driving a stick as long as its not a work - out....my 1986 - GT was fine.....if this Mach is also too hard I will sell it & stick with my 2007 Honda Accord
Old 12-05-2016, 06:17 PM
Rick Gonzalez
Got my Mach 1 today & the clutch is awesome....easy & smooth shifting....just like new.....my first one obviously had issues .....thanx for your input !
Old 12-11-2016, 01:22 PM
Stone629
Stone629's Avatar
The grabbing right off the floor thing is usually a cable issue. Mine was doing that a few weeks ago, swapped it out, all good. All new edge mustangs have heavy pedaled clutches. Op, glad to hear your new Mach is tip top!
Stone629 is offline
Old 12-11-2016, 06:07 PM
Rick Gonzalez
Yes....mine is like new....easy & smooth.....I thought the new mustangs had easy hydraulic clutches ?
Old 12-11-2016, 06:20 PM
Z28KLR
Z28KLR's Avatar
Mine begins to engage literally right off the floor but it's due to using the MM clutch pedal height adjuster. It repositions the pedal so it's level with throttle and brake, basically takes that section of play out of the pedal and cable. You get used to it after a few minutes, lol.
Z28KLR is offline
Old 12-14-2016, 09:54 AM
Rick Gonzalez
Well. put....I guess if law enforcement can cover the bases...then it's up to us to save ourselves & vehicles....some people are teachable & others are not
Old 12-14-2016, 09:55 AM
Rick Gonzalez
Sorry...this message looks like it posted on wrong thread ?
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: hard clutch.
