Mass Chit-Chat
#41
I would try to tackle the install myself if I had a garage or somewhere(and the tools) to do it, doesn't look that hard. Especially with the drop in fuel hat I bought. So I'm probably gonna have my buddy's step dad do it for me(senior master tech for ford, and has a very nice lightning) he's gonna charge me but not what most other shops would. it all depends on install time. But at the same time as the kit is going in I'm upgrading to the 07+ cooling setup too.
#43
I went with the S&H Performance Stage 1 setup. From the same guys who make that Turbo kit you pointed out. Basically a modified GT fuel hat with a 340lph fuel pump along with upgraded wiring.
http://www.s197forum.com/forum/showthread.php?t=77625
says will support up to 500-550 depending on injector size. When it comes time to upgrade the pump after that I'll probably end up going with their stage 2 if I like this setup, basically a GT fuel hat with dual 340lph pumps and a second FPDM and upgraded wiring kit. and that setup is only $525
#44
Let me know how it works out. I know there was a guy over on a different forum that used a 340lph pump on a stock hat (with wiring upgrade) and the thing was MAXED at 480rwhp.
I think it has something to do with the single FPDM trying to drive such a larger than stock pump.
I haven't seen any results with Jeremy's kit yet, so give us all the details when it comes time. Who's doing the tune? I would hope Pete?
I haven't decided what I want to do for a fuel setup yet... ugh
#45
Should start to see some packages today.
#47
Not necessarily. My pinion angle was very off so i needed an adjustable as well. Only running the saleen springs too.
#49
If you're lowered you'll def want an adjustable upper (a must with a 1 piece DS too), LCA relocation brackets to bring the LCA's back level, and sometimes a panhard bar to re-center the rear.
#50
Parts started arriving today, nothing too exciting. Got most of the 07 coolant setup, just waiting on upper radiator hose and the t-stat. and the discharge assembly showed up, still waiting on everything else though.
