OLD 347 stroker 95 GT
MY 347 stroker idling
if vid doesnt work here is the link to it on youtube
http://www.youtube.com/watch?v=EaKkILNPOZo#GU5U2spHI_4
a small list of mods
347 stroker fully forged
Balanced rotating assembly
lunati nitrous cam
zex 125 shot
ford racing lifters
1.6 roller rockers
comp cams hardened pushrods
ac delete
trickflow track heat
3/8 intake spacer
bbk tb 70mm
C&L 76mm kit with MAS
reworked e7's have been ported 3 angle valve job milled 40 185 160 valve's
dual valve springs
double roller timing chain
#30 injectors
msd 6al box
msd rpm selector
msd bronze dizzy gear
zex purge kit
zex rapid fire kit
professional products harmonic balancer
BBK long tubes Headers
BBK ORHP
BBK Pulleys
BBK 190lph fuel pump
BBK Fuel Pressure regulator
BBK Fuel liquid guage
Ford Racing 9mm wires
super 40 flowmasters
UPR smog pump delete kit
MSD Blaster coil
MSD Cap and Rotor
Pro 5.0 short shifter
BBK Adjustable Clutch Quadrant and firewall adjuster
Centerforce Dual Friction clutch
3.73s
D&D K-Member
D&D Coilovers (150lbs spring rate)
D&D tublar a-arms
Lakewood traction bars
BBK heavy duty upper control arms
BBK subframe connectors
BBK lowering springs
BBK caster camber plates
solid motor mounts and tranny mount
battery relocated to trunk
Lakewood 90/10's
Lakewood 50/50's
Removed front sway
Removed Backseat
RE: OLD 347 stroker 95 GT
ORIGINAL: bikeboy587
BBK wouldn't be one of your favorite companies would it? jk
YoungStangsMan
09-05-2015 07:01 PM
