my 69 mustang coupe with an LS1 & 6 speed
Old 02-16-2012, 07:35 PM
badwolf4822
badwolf4822's Avatar
I have about 3 inches each side of the engine. My headers and spark plugs fit fine, went with iridium pulsars so about $25 each but supposed to spark 2x to burn fuel better.
trans mount
cut the top of the radiator support out so the engine would go in more smoothly, so why not make it tubular and removable
9.5in rear end
gauges I'm using, basic 6 so far but I'm going to add stuff like pitch and yaw, and probably an artificial horizon, and if i can find a way to have an altimeter
top box is the 69 mustang chassis harness, just gonna cut out all th engine parts
lower box is the computer and wiring for a de-smogged ls1, gonna have to dino tune before it will run well
just dropped of my yokes and measurements to have a drive shaft built
said it would be around $500 at pickup for the toughest one they could make
badwolf4822 is offline
Old 02-17-2012, 11:34 AM
jer305
jer305's Avatar
Wow looks like your on a roll! Thanks for the pics.
jer305 is offline
Old 02-17-2012, 11:39 AM
jer305
jer305's Avatar
You said your headers are fitting just fine, so they clear the steering (not pointing right at it)? What heads are those? If they are stock corvette what year did they come from?
jer305 is offline
Old 02-17-2012, 02:09 PM
badwolf4822
the heads are stock for an 02 corvette
and the headers end above the steering box, shorties is the best I could fit, but still 3in collector
plus the steering box is an after market 16:1 power steering kit so actually little different shape than the stock box
my plan for exhaust is 3in all the way with and X in the middle to equalize back pressure ending in dual flow-master 50s, which I've found a way to stand on edge between the fuel cell and the leaf springs, so maximum ground clearance
just got to wait for my drive-shaft then its off to the exhaust shop
I want to get all the metal work done on the car and painted with rubberized coating before I start on wiring, hope its as painless as they say, did on of these kits on my 70 camaro while back and it took all day, at least the ls1 kit is mostly just plugs and no soldering
Old 02-20-2012, 08:47 PM
badwolf4822
in the middle of replacing the only panel that really had any rust
just need to weld it in place
the hard part was getting the old one out
had to drill out all the spot welds and still cut it into several pieces
Old 02-21-2012, 01:45 PM
jer305
jer305's Avatar
and the headers end above the steering box, shorties is the best I could fit, but still 3in collector...
What shorties did you go with? have any pics with them installed?
jer305 is offline
Old 02-21-2012, 02:06 PM
badwolf4822
Headman block huggers. They come straight down from between the last 2 cylinders. I'll post a pic later.
Old 02-26-2012, 11:54 AM
Apstang50
Apstang50's Avatar
I'm not one for chevy anything, but a very cool project you got going!
Apstang50 is offline
Old 03-03-2012, 05:34 PM
badwolf4822
made my trans tunnel today
Old 03-03-2012, 07:17 PM
1slow67
ROTM Moderator
1slow67's Avatar
This is an awesome build
1slow67 is offline
Quick Reply: my 69 mustang coupe with an LS1 & 6 speed
