my 69 mustang coupe with an LS1 & 6 speed
#44
got some actual tuned headers to fit by mixing 2 kits, with a little modification
installed coil packs, plugs, and wires
still debating on ordering msd coils now or later
and decided on these 17s to replace the 20s it has now
#46
tail lights finally installed, been waiting on the studs
they are also sequential turn signals like new mustangs
running a power block from west marine to simplify the wiring around the battery
installed the electric fan, still working out a sensor so it will still run till the engine cools after the car is shut off
working out all the wiring and finally mounted the ecu under the dash
doing some more mock up of parts on the dash
spent for ever trying to bleed the system with kevin only to come to the conclusion I just need to get a single direction cutting brake and a line lock kit
#49
installed my new brake master cylinder
took a lot of work on the shaft length and pedal travel
and still need to bleed the system
all brake system plumbing done
installed my side mirrors
and put the hood back on
