Lidio is doing his fall dyno day that Saturday so I will be heading over to Alternative Auto. Good luck at the track though! I'm sure we will see each other there sometime before the season ends.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
im sure we will jim, i actually did see you a few weekends back but i didnt come over to chat with you and jack. i talked to jack earlier before you got there though. how did the new power adder treat you?
Still getting used to it and learning how to launch it. Best so far is only a 13.8, so not quite where I was with the nitrous but launch is very different with boost right out of the hole. The nitrous didn't come on until I was at the 60' and now I am doing some spinning with the boost coming on so quick on the Xcharger.
__________________
ah, you have good tires too. using my street tires sucks at lapeer, as any dragstrip really, usually i can launch fine with minimal spin and get 2.1 60' but as soon as i shift into second they break loose and stay that way until i need to shift to third. losing a lot of time. i need to save up for some good tires and maybe ill hit 14.4s or 5s
