Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Step by Step guide to installing a Mark VIII motor in a 96+ GT.
Old 02-19-2012, 08:42 PM
  #91
1998Slow 'Stang
1998Slow 'Stang's Avatar
Originally Posted by bbbilly426
Of what a 5.0 motor now. Not just going to 5.0. I want to use carburetor and I did not find out for couple other things go to work
Really? Is this the best you can do?
1998Slow 'Stang is offline
Old 03-01-2012, 07:28 PM
  #92
acth4347
acth4347's Avatar
I have a 96 GT 2V that I am swapping out with a 98 Cobra 4V SVT. I have an 8 bolt flywheel that will take the 10.5 in clutch and should have no problem bolting up to the T-45. I also have the wiring harnesses so I can run with the IMRC's and plan to delete all smog with the tune. My question is, can I get my GT ECU/PCM re-flashed with a stock 98 Cobra program and do tunes/smog deletes from there? Or are the computers physically different? Any advice is appreciated, thanks.
acth4347 is offline
Old 03-01-2012, 07:37 PM
  #93
1998Slow 'Stang
I would find out if this has to/will pass CA smog even if everything is hooked up right. Makes me glad I live in the land of not caring about emissions.
Old 03-02-2012, 12:20 AM
  #94
acth4347
acth4347's Avatar
I am building a "special construction" 1965 Cobra replica. I will be registering it under SB100, and that means I can smog it as a '65. I will only have to worry about crankcase venting to the intake. The dilemma is I don't know if the ECU/PCM is the same physically and just needs reflashing to a 98 Cobra program or if I will have to buy a Cobra computer. Thanks again.
acth4347 is offline
Old 03-02-2012, 04:19 AM
  #95
JC316
JC316's Avatar
Yes, it's the same ECM and should flash without issue.
JC316 is offline
Old 06-08-2012, 10:56 PM
  #96
Stangbuilder2000
Stangbuilder2000's Avatar
I just completed this swap on my 2000 gt along with an auto to manual swap but the motor is sputtering like it has a bad vacuum leak, but misfires and runs worse going up hill making me think it's fuel delivery related. The plugs are used but still have plenty of miles on them. I'm still using the SOHC/ automatic ecu and the car is barely running. I've checked my electrical and vacuum lines over and over, seems like it might be getting too much fuel? Or maybe the computer is just freaking out? After scanning it the only 2 codes I got were for the automatic trans but maybe those codes are causing the problem idk. Any help would be great!!
Stangbuilder2000 is offline
Old 06-09-2012, 01:31 AM
  #97
JC316
JC316's Avatar
What did you do about the fuel rail? Isn't the 2000 a returnless setup? If the fuel pressure regulator is effing up, it might cause those symptoms.
JC316 is offline
Old 06-09-2012, 01:21 PM
  #98
Stangbuilder2000
I used the factory 2000 gt fuel rails and the factory regulator, just did a bit of welding on the rails to make the crossover line work. Still a returnless style, do I just run the vacuum from the fuel rail mounted regulator straight to the intake? Not sure because I bought the car with no top end on the engine and didn't get to see how everything went together forsure
I'm using 96 mark viii injectors, other than that it's all the factory fuel system
Old 06-09-2012, 01:57 PM
  #99
Stangbuilder2000
Is there any way to test if it's bad? It has power to it and isn't throwing any codes
Old 06-09-2012, 04:53 PM
  #100
JC316
JC316's Avatar
I can't help you much there, I have only had one returnless setup mustang and it never had a problem. You might make a thread in the 4.6L section asking about it.
JC316 is offline
Quick Reply: Step by Step guide to installing a Mark VIII motor in a 96+ GT.
