Step by Step guide to installing a Mark VIII motor in a 96+ GT. - Page 11 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 06-09-2012, 05:50 PM   #101
BlackMage
BlackMage's Avatar
sounds like just a bad misfire and not related to fuel. check for a cracked plug, bad sparkplug wire/boot, bad ground on one of the coils...
BlackMage is offline   Reply With Quote
Old 06-10-2012, 11:20 AM   #102
1998Slow 'Stang
Quote:
Originally Posted by Stangbuilder2000 View Post
I used the factory 2000 gt fuel rails and the factory regulator, just did a bit of welding on the rails to make the crossover line work. Still a returnless style, do I just run the vacuum from the fuel rail mounted regulator straight to the intake? Not sure because I bought the car with no top end on the engine and didn't get to see how everything went together forsure
I'm using 96 mark viii injectors, other than that it's all the factory fuel system
Unless you got the car tuned put the stock 2000 gt injectors back in. The Lincoln has 24lb/hr and the GT is tuned for 19lb/hr. Therefore your motor is drowning in fuel.
1998Slow 'Stang is offline   Reply With Quote
Old 06-10-2012, 12:25 PM   #103
BlackMage
BlackMage's Avatar
Quote:
I have been running 24 lb/hr's in mine for almost 6 months now with no issues... on the GT computer and tune. Ive read a lot of people not having this being an issue... just sayin.
Old 06-10-2012, 07:00 PM   #104
1998Slow 'Stang
Quote:
Hmmm, thats interesting. I've not tried running my 24s from my lincoln motor so I can't argue your point, but that is certainly food for thought.
Old 06-10-2012, 07:27 PM   #105
JC316
JC316's Avatar
It wont be the injectors. I was running 5 24lbs and 3 19lbs on mine without issue lol.
JC316 is offline   Reply With Quote
Old 06-10-2012, 09:03 PM   #106
BlackMage
BlackMage's Avatar
Quote:
haha i remember you telling me this, i still find it hilarious that it even runs!
Old 06-30-2012, 09:19 AM   #107
48prerunner
Great Thread Has me rethinking putting a 4.6 3v in my 69-f100 MarkVIII motor would be alot cheaper.
48prerunner is offline   Reply With Quote
Old 04-17-2013, 12:37 PM   #108
mustangman02232
mustangman02232's Avatar
What Power level are the 19 lb injectors good to? Can I run bolt ons without running out of fuel?
Also what's everyone run for gears with this swap, I haven't installed my 3.73 yet but from the dyno # posted a few pages back with the power mid range should they be goid
Will I need to have the PATS system reworked in my 99 or can I still have sct tunes written for the swap
mustangman02232 is offline   Reply With Quote
Old 04-17-2013, 01:06 PM   #109
BlackMage
BlackMage's Avatar
300 is about max for the 19's. If you have a stock 4v motor, you'll be fine with the 19's. if you start upgrading it, i would get rid of them asap.
Old 03-24-2014, 02:44 PM   #110
supercotufa
supercotufa's Avatar
Post 93 Mark VIII engine
Great write up. You summarized most of the answers I was looking for.
I am looking at a 93 Mark VIII Teksid engine with the old style intake and 128K miles.
1) Does the IMRC work with vacuum controls, and if so, does it work automatically without the ECC intervention?
2) Will the throttle body type and location be compatible with a 98 GT?
supercotufa is offline   Reply With Quote
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 12:47 PM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 10:49 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 4.6L (1996-2004 Modular) Mustang 1 08-26-2015 11:29 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 General Tech 2 08-26-2015 08:32 PM
Installing new hood jlopez07 2005-2009 S197 Appearance Section 1 08-21-2015 09:28 AM
98, 99, ac, cobra, coolant, delete, engine, fit, fuel, hose, mark, mustang, rails, remove, transmission, viii, wiring
