Step by Step guide to installing a Mark VIII motor in a 96+ GT. - Page 13 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 04-02-2014, 09:27 AM   #121
BlackMage
BlackMage's Avatar
you're also going to need to find the correct valve covers. the 97-98 mark's had COP's, so if you get those you will need to change your ignition to COP's instead of coil packs. Otherwise you can find any 96-98 or 93-96 4v valve covers and re-use your coil packs.
BlackMage is offline   Reply With Quote
Old 04-08-2014, 07:13 PM   #122
supercotufa
supercotufa's Avatar
The engine that I bought had been opened: the guy took out the valve covers and the upper intake. With the intense rainy season the engine got flooded, with about 3 gal of water on the pan, and about 1/2 gal in the intake.
I took it apart and cleaned it up. Amazingly enough the engine seem to still be in good shape, and after a good clean it spins freely.
I found a considerable amount of carbon deposits in the intake, mostly I the non-injected ports, and a couple of square ports with deposits.
How concern should I be in regards to the state of the engine?
I am in a tight budget and am trying to avoid taking the heads off, but want to make things the right way.
supercotufa is offline   Reply With Quote
Old 07-22-2014, 04:25 PM   #123
jakemarsh7
I'm doing this on a 99 GT. I got the 96-98 cobra intake manifold, so should I still be using a 99-01 cobra intake tube or should I use the 96-98 intake? I think the only way that a cobra strut tower brace will fit is if I get the 96-98 one.
jakemarsh7 is offline   Reply With Quote
Old 07-23-2014, 04:38 PM   #124
BlackMage
BlackMage's Avatar
Quote:
you'll need the 96-98 cobra intake tube.
Old 07-28-2014, 02:50 AM   #125
tinkercameron
so im starting this swap this week. I have a 93 engine. can someone tell me what parts I will have to get, besides what I have on the Lincoln and my 97 gt.
tinkercameron is offline   Reply With Quote
Old 07-28-2014, 08:46 PM   #126
jakemarsh7
I'm doing this on my 99 GT, which has a returnless fuel system. anything special have to be done, or do i just have to use the mark-viii fuel lines and that's it?
Old 07-28-2014, 10:37 PM   #127
tinkercameron
can I use the 93 intake in this swap on my 97 or do I need the 96-98 intake? and why do you need cobra manifolds for the swap? why cant you use the ones already on there
Old 08-01-2014, 12:11 PM   #128
BlackMage
BlackMage's Avatar
the parts you need all depend on the route you want to go.
the 93 mark viii intake WILL NOT WORK.
Go back through the posts here, theres not a lot of them. From post #100 on up, you should be able to anwer your questions on the intake part of it.
Old 08-06-2014, 12:54 AM   #129
tinkercameron
I am on a very tight schedule as im leaving for college in 2 weeks. I am using a 96-98 intake and a 99-04 cobra manifold. will I absolutely need 96-98 cobra imrc plates and a different throttle cable. and if so, what year.
Old 08-06-2014, 10:30 AM   #130
BlackMage
BlackMage's Avatar
Quote:
reading takes all of 30 min. lol
as for the imrc's, you will need either the 96-98 cobra plates, or the 97-98 mark viii plates. because you are using a 96 cobra intake, you will need to use a 96-98 cobra throttle cable.
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 01:47 PM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 11:49 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 4.6L (1996-2004 Modular) Mustang 1 08-27-2015 12:29 AM
Window Motor(new) Issue: Opposite Direction HorsePower99 General Tech 2 08-26-2015 09:32 PM
Installing new hood jlopez07 2005-2009 S197 Appearance Section 1 08-21-2015 10:28 AM
98, 99, ac, cobra, coolant, delete, engine, fit, fuel, hose, mark, mustang, rails, remove, transmission, viii, wiring
